Discuss
Maytag oven (range) control panel only displays temp of 100
 in
I have a maytag range (I don't have the model number right now, I will get it shortly). On the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag oven (range) control panel only displays temp of 100
  #1 (permalink)
Old 05-12-2017, 01:32 PM
Junior Member
jeloqim is on a distinguished road
Default Maytag oven (range) control panel only displays temp of 100
Brand: Maytag   Age: 5 - 10 years
I have a maytag range (I don't have the model number right now, I will get it shortly). On the control panel when I click 'bake' the display shows a temperature of 000 and then I click the 'more' button and it goes to 350 and then I leave it and then the display shows a temperature of 100. The oven heat turns on. I open the oven and I see red glow heating and after a few minutes the oven is very hot (most definitely above 100), but the control panel display shows only a temperature of 100. I click 'bake' and then 'less' and bring the temperature to 200, but the oven stays on and keeps increasing in temperature. It seems like the temperature sensor is broken? Or perhaps the control panel? What do you think is most likely the problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front control panel displays " locked' flame1010 Oven Repair (including Ranges and Cooktops) 0 12-14-2011 07:14 PM
Oven control panel locked up; displays F-7 Flyingmike Oven Repair (including Ranges and Cooktops) 0 10-02-2010 11:26 AM
Control panel displays OFF mosc2 Oven Repair (including Ranges and Cooktops) 1 07-09-2009 03:44 PM
Maytag range control panel roblibby Oven Repair (including Ranges and Cooktops) 1 02-17-2009 07:32 AM
oven & temp control panel dims while heating thepurpleheron Oven Repair (including Ranges and Cooktops) 1 11-29-2008 04:17 AM
