I have replaced my oven ignitor 3 times in the past month. I have installed it and turned on the oven to 300 degrees and its been fine then the second time I tried it it didn't go over 100 degrees. I opened the bottom panel and the ignitor was in pieces. This happened 3 times in the past month all on the 2nd time I tried the oven. Any ideas? I even tried ordering from different parts stores.
Thanks in advance Phil
