Discuss
oven underheats and now makes whoosing noise
 in
The oven is not heating properly. First noticed with a ham that came out still cold after normal cooking time
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven underheats and now makes whoosing noise
  #1 (permalink)
Old 04-24-2017, 08:16 PM
Junior Member
facerat is on a distinguished road
Default oven underheats and now makes whoosing noise
Model Number: ARGS7650SS   Brand: Amana   Age: More than 10 years
The oven is not heating properly. First noticed with a ham that came out still cold after normal cooking time and then it was an undercooked pizza. Display shows temp selected but oven does not reach temperature selected. Tested with an oven thermometer and it is between 75 and 100 degrees lower than the oven temp displayed. After following an owners manual procedure to increase oven temp setting the oven began making loud whoosing sounds like either gas rushing or air rushing thru something. Is this two separate problems or is there a known likely suspect I should start with?
Related Models
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Amana ARHC8700WW RANGE- S/C F/S ELE
Amana ARHSC8750E RANGE- S/C S/I DDRAFT ELE
Amana ARHSC8750WW RANGE- S/C S/I DDRAFT ELE
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L RANGE- S/C S/I DDRAFT GAS
Amana ARO3100W RANGE- S/C S/I DDRAFT GAS
Amana ARO3400L RANGE- S/C S/I DDRAFT GAS
Amana ARO3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR-201 RANGE- S/C S/I DDRAFT ELE
Amana ARR-201 RANGE- S/C S/I DDRAFT GAS
Amana ARR-401 RANGE- S/C S/I DDRAFT ELE
Amana ARR-401 RANGE- S/C S/I DDRAFT GAS
Amana ARR-402 RANGE- S/C S/I DDRAFT ELE
Amana ARR-402 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT ELE
Amana ARR-412 RANGE- S/C S/I DDRAFT ELE
Amana ARR-415 RANGE- S/C S/I DDRAFT ELE
Amana ARR101W RANGE- S/C S/I DDRAFT ELE
Amana ARR301 RANGE- S/C S/I DDRAFT ELE
Amana ARR301W RANGE- S/C S/I DDRAFT ELE
Amana ARR303 RANGE- S/C S/I DDRAFT ELE
Amana ARR303W RANGE- S/C S/I DDRAFT ELE
Amana ARR305 RANGE- S/C S/I DDRAFT ELE
Amana ARR3100L RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NL RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NW RANGE- S/C S/I DDRAFT GAS
Amana ARR3100W RANGE- S/C S/I DDRAFT GAS
Amana ARR3400L RANGE- S/C S/I DDRAFT GAS
Amana ARR3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR3601LL Range - S/c S/i Ddraft Gas
Amana ARR3601LL RANGE- S/C S/I DDRAFT GAS
Amana ARR3601WW Range - S/c S/i Ddraft Gas
Amana ARR3601WW RANGE- S/C S/I DDRAFT GAS
Amana ARR5200L RANGE- STD MWAVE ELE
  #2 (permalink)
Old 04-27-2017, 02:09 PM
Junior Member
Default Anybody??????????????
How about just a place to start???????Does anyone come to this forum?
  #3 (permalink)
Old 05-02-2017, 06:15 AM
Junior Member
Default
Ok, so I took out the oven sensor and tested with an Ohm meter, and it tests at 1074. Is this part considered close enough to the 1100 benchmark? The igniter however tests at 170 ohms, ?? When I press " bake " the oven digital display will beep within a few minutes that the temp is at 350 although it is obviously not there. Watching the igniter it glows orange and turns on and off appx every minute or so and also shut the flame down. Anyone have a thought. The whooshing noise seems to be gone for the moment. Appreciate any thoughts?
  #4 (permalink)
Old 05-17-2017, 06:09 PM
Junior Member
Default
what a lousy ********ing forum this this is!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas oven makes sputtering noise Harryscary Oven Repair (including Ranges and Cooktops) 0 10-08-2013 06:12 PM
Maytag oven pulsing whoosing sound and oven will not preheat well rcubed1 Oven Repair (including Ranges and Cooktops) 0 09-20-2012 04:32 PM
oven makes noise when lit albecca728 Oven Repair (including Ranges and Cooktops) 0 07-16-2011 03:07 PM
Oven Fan makes noise robertlowman Oven Repair (including Ranges and Cooktops) 1 11-26-2010 05:10 AM
Oven makes noise when igniting Wendy Oven Repair (including Ranges and Cooktops) 3 03-29-2009 09:14 AM
