Discuss
Old Hotpoint - low flame & no heat in oven
 in
I have an older hotpoint oven in a cabin that has had some issues recently. I have tried searching the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Old Hotpoint - low flame & no heat in oven
  #1 (permalink)
Old 04-24-2017, 12:34 PM
Junior Member
bcy42 is on a distinguished road
Default Old Hotpoint - low flame & no heat in oven
Brand: Hotpoint   Age: More than 10 years
I have an older hotpoint oven in a cabin that has had some issues recently. I have tried searching the forums for similar issues, but have come up empty. Any advice is appreciated so I can diagnose once I go back this weekend.
I didn't get the model number while I was there, but it is an LP stove, pilot light ignition, no electricity whatsoever.
Symptoms:
Pilot light will light, but will go out once I turn the knob down below 250 degrees. The top burners have been very small for a long time. Before I could turn two on at a time, though they would be very small flames. This last weekend I barely was able to light the one burner it was such a small flame coming out.
I have tried:
Filling LP bottle
Replacing regulator
checking line for kinks/leaks
Unhooked propane and open all knobs (that seemed to make it worse once I turned it back on)
Thanks for any help!
  #2 (permalink)
Old 04-24-2017, 02:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Where is your cabin located? If it's up in mountains at high elevation, it could cause such problem with the surface burners.
Also, possible the oven thermostat has gone bad.
Who and how convert the range to LP?
The complete model number of the range would definitely help.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-02-2017, 08:18 AM
Junior Member
Default
Thank you for your response, I just got back with the model number.
RGA520 PW3WH.
It isn't up higher than 1,500'.
It has been converted to LP for years- always been at this cabin and worked fine up until a few years back with the seemingly drop in pressure.
  #4 (permalink)
Old 05-02-2017, 02:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by bcy42 View Post
I have tried:
...Replacing regulator...
Which regulator had you replaced?
Very likely the cause of the problem is a faulty LP pressure regulator. Unfortunately, this part is no longer available. Looks like it's a time for a new range.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool gas dryer won't heat already replace the coils and flame sensor and no heat Joseph1976 Dryer Repair 0 05-30-2014 09:00 AM
Hotpoint Electric Oven Won't heat krausjw Oven Repair (including Ranges and Cooktops) 3 02-24-2014 06:12 PM
1966 Hotpoint electri double oven wont heat up rossb1 Oven Repair (including Ranges and Cooktops) 0 09-05-2009 08:53 AM
hotpoint propane/electric stove low bottom flame fusion1620 Oven Repair (including Ranges and Cooktops) 3 07-10-2009 08:27 AM
Hotpoint gas oven won't heat to temp jetmech Oven Repair (including Ranges and Cooktops) 11 07-31-2008 03:53 PM
