Discuss
problem repairing power burner/simmer select on Kenmore stove
 in
I have a problem with my stove top that appears to be common and I have tried the usual suggestions
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » problem repairing power burner/simmer select on Kenmore stove
  #1 (permalink)
Old 04-23-2017, 12:06 PM
Junior Member
crftsmn is on a distinguished road
Default problem repairing power burner/simmer select on Kenmore stove
Model Number: 790-9644208   Brand: Kenmore   Age: 5 - 10 years
I have a problem with my stove top that appears to be common and I have tried the usual suggestions with no luck. It is a Kenmore 790-9644208.
The front left power burner has stopped working a long time ago. I remember there being a pop noise of some kind and I now know that is usually indicative of a simmer select board going out. At the time I didn't know that so I replaced the Surface Element Control with part #316436001. No luck.
I brought the burner to a local appliance repair shop and he tested continuity and it checked out according to him. He thinks the burner is good.
I later replaced the simmer select switch with 5303935217 thinking it would be a cheaper fix attempt then the simmer select control board (at the time I was confusing the simmer select control board with the main control board). The new switch has 5 connectors instead of just 2. But I know manufacturers sometimes substitute parts. I guessed which lead to use and as far as I can tell it is working as the simmer light does come on (I don't even remember if the light came on before or not). And again no luck with the burner.
I bought and installed a used simmer select control board #316429301. Still no luck with the burner. However i do now hear clicking noise coming from the simmer control board that sounds like it is coming on and going off so I think the board is good - or at least better than the old one.
I would still like to get this working before having to resort to a new stove. Here are my thoughts
  1. The Surface Element control switch is wired wrong or bad. I can't find any reference other than a wiring diagram to verify it is correct. The wiring diagram is too complicated for me to understand. I am pretty sure I connected all the wires to the new switch just like they were on the old one. I do have the original switch and could put it back in again.
  2. The simmer select switch is not correct or wired wrong. Again the new one has 5 connectors instead of 2. I used a pair of connectors on the new one that appear to coordinate and as I said the simmer board is making on/off noises so I think the switch is OK.
  3. The element is in fact bad
  4. the used simmer control board is bad despite the noise I hear from it.
I am going to try putting the old control switch and simmer switch in again - one at at time so I will know what fixed it if it works. Beyond that I lost. Any suggestions would be great.
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 04-30-2017, 12:50 PM
Junior Member
Default
I don't know if anyone is reading this thread but I reinstalled the original Surface Element control switch and the original simmer select switch. There was no change in behavior except that the Element On light is now on all the time - I mean the general one off to the right, not the light specific to any one burner.
I did notice that when I test the other burners I can hear a low hum that comes on immediately. I do not hear that when I test the front right burner that I am trying to repair.
Again I would love any suggestions that anyone has.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore stove duplex burner problem scf Oven Repair (including Ranges and Cooktops) 0 07-07-2012 09:16 PM
Simmer Select Switch BenN Oven Repair (including Ranges and Cooktops) 0 03-22-2011 12:15 PM
Kenmore Simmer Burner Not Working kolo909 Oven Repair (including Ranges and Cooktops) 0 03-01-2010 08:42 AM
Kenmore right rear simmer burner issue pfp888 Oven Repair (including Ranges and Cooktops) 1 01-29-2009 04:43 PM
Left front simmer burner problem KevinR Oven Repair (including Ranges and Cooktops) 0 05-27-2008 07:25 PM
