My freinds oven light was staying always on so i figured it was the oven door switch so i installed the new one and still the same problem. I tried also to bypass the switch going directly from the line source to the switch and socket and iliminated the self clean connection. Now i get the light on when door is closed and light off when door open.i really need help how to make it work. The light switch on the control board does nothing at all neither close or open
