Discuss
No Heat In Top Oven
 in
We have a Maytag double oven. When we turn on the top oven, it heats to about 150 then stops.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No Heat In Top Oven
  #1 (permalink)
Old 03-23-2017, 12:31 PM
Junior Member
ajswanson04 is on a distinguished road
Default No Heat In Top Oven
Model Number: CWE5800ACB   Brand: Maytag   Age: 5 - 10 years
We have a Maytag double oven. When we turn on the top oven, it heats to about 150 then stops. We have tested the bottom element and the temperature sensor and all is good there. The broil element will work in the upper oven. The lower oven works as it should. The clock works. Could this be a relay problem? And if so, how do I test that? If not, I'm assuming the only thing left is to replace the main board. Any help would be appreciated.
Related Models
Maytag CWE5800ACB WALLOVEN- S/C ELE
Maytag CWE5800ACB25 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACE WALLOVEN- S/C ELE
Maytag CWE5800ACE28 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACS WALLOVEN- S/C ELE
Maytag CWE5800ACS14 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE600 WALLOVEN- S/C ELE
Maytag CWE601 WALLOVEN- S/C ELE
Maytag CWE602 WALLOVEN- S/C ELE
Maytag CWE6020ACB WALLOVEN- S/C ELE
Maytag CWE6200ACB WALLOVEN- S/C ELE
Maytag CWE6200ACE WALLOVEN- S/C ELE
Maytag CWE6200ADB WALLOVEN- S/C ELE
Maytag CWE6200ADE WALLOVEN- S/C ELE
Maytag CWE6230ACB WALLOVEN- S/C ELE
Maytag CWE6230ACE WALLOVEN- S/C ELE
Maytag CWE6230ADB WALLOVEN- S/C ELE
Maytag CWE6230ADE WALLOVEN- S/C ELE
Maytag CWE6800ACB WALLOVEN- S/C ELE
Maytag CWE6800ACE WALLOVEN- S/C ELE
Maytag CWE6830ACB WALLOVEN- S/C ELE
Maytag CWE6830ACE WALLOVEN- S/C ELE
Maytag CWE700 WALLOVEN- S/C ELE
Maytag CWE7000ACB WALLOVEN- S/C ELE
Maytag CWE7000ACE WALLOVEN- S/C ELE
Maytag CWE701 WALLOVEN- S/C ELE
Maytag CWE7800ACB WALLOVEN- S/C ELE
Maytag CWE7800ACE WALLOVEN- S/C ELE
Maytag CWE7830ACB WALLOVEN- S/C ELE
Maytag CWE7830ACE WALLOVEN- S/C ELE
Maytag CWE900 WALLOVEN- S/C ELE
Maytag CWE9000ACB WALLOVEN- S/C ELE
Maytag CWE9000ACE WALLOVEN- S/C ELE
Maytag CWE9000BCB WALLOVEN- S/C ELE
Maytag CWE9000BCE WALLOVEN- S/C ELE
Maytag CWE9000BCM WALLOVEN- S/C ELE
Maytag CWE9000BDB WALLOVEN- S/C ELE
Maytag CWE9000BDE WALLOVEN- S/C ELE
Maytag CWE9000CDB WALLOVEN- S/C ELE
Maytag CWE9000CDE WALLOVEN- S/C ELE
Maytag CWE9000DDB WALLOVEN- S/C ELE
Maytag CWE9000DDE WALLOVEN- S/C ELE
Maytag CWE9030BCB WALLOVEN- S/C ELE
Maytag CWE9030BCE WALLOVEN- S/C ELE
Maytag CWE9030BDB WALLOVEN- S/C ELE
Maytag CWE9030BDE WALLOVEN- S/C ELE
Maytag CWE9030DDB WALLOVEN- S/C ELE
Maytag CWE9030DDE WALLOVEN- S/C ELE
Maytag CWE9900 WALLOVEN- S/C ELE
Admiral CWEA100ACB WALLOVEN- STD ELE
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF310GSA ELECTRIC RANGE
White Westinghouse CWEF310GSB ELECTRIC RANGE
White Westinghouse CWEF310GSC ELECTRIC RANGE
White Westinghouse CWEF310GSD ELECTRIC RANGE
White Westinghouse CWEF310GSE ELECTRIC RANGE
White Westinghouse CWEF310GSF ELECTRIC RANGE
White Westinghouse CWEF311ES1 White Westinghouse/electric Range
White Westinghouse CWEF312ES1 Ww Canada/electric Range
White Westinghouse CWEF312FSA Ww Canada/electric Range
White Westinghouse CWEF312FSB White Westinghouse/range
White Westinghouse CWEF312GSA ELECTRIC RANGE
White Westinghouse CWEF312GSB ELECTRIC RANGE
White Westinghouse CWEF320ES1 Whiet Westinghouse Canada/electric Range
White Westinghouse CWEF322ES1 Ww Canada/electric Range
White Westinghouse CWEF322ES3 W - W Canada/electric Range
White Westinghouse CWEF322ES4 Ww Canada/electric Range
White Westinghouse CWEF322ES5 Ww Canada/electric Range
White Westinghouse CWEF355ES1 White Westinghouse/electric Range
Maytag CWG300 WALLOVEN- STD GAS
Maytag CWG301 WALLOVEN- STD GAS
Maytag CWG302 WALLOVEN- STD GAS
Maytag CWG3020AAB WALLOVEN- STD GAS
Maytag CWG3020AAE WALLOVEN- STD GAS
Maytag CWG3020BAB WALLOVEN- STD GAS
Maytag CWG3020BAE WALLOVEN- STD GAS
Maytag CWG3100AAB WALLOVEN- STD GAS
Maytag CWG3100AAB25 24" BUILT-IN GAS OVEN
Maytag CWG3100AAE WALLOVEN- STD GAS
Maytag CWG3100AAE29 24" BUILT-IN GAS OVEN
Maytag CWG3100AAS WALLOVEN- STD GAS
Maytag CWG3100AAS13 24" BUILT-IN GAS OVEN
Maytag CWG351 WALLOVEN- STD GAS
Maytag CWG3510AAB WALLOVEN- STD GAS
Maytag CWG3510BAB WALLOVEN- STD GAS
Maytag CWG3600AAB WALLOVEN- STD GAS
Maytag CWG3600AAB26 24" BUILT-IN GAS OVEN
Maytag CWG3600AAS WALLOVEN- STD GAS
Maytag CWG3600AAS13 24" BUILT-IN GAS OVEN
Maytag CWG400 WALLOVEN- STD GAS
Maytag CWG401 WALLOVEN- STD GAS
Maytag CWG402 WALLOVEN- CONT CLEAN GAS
Maytag CWG4020AAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4020BAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4100AAB WALLOVEN- STD GAS
Maytag CWG450 WALLOVEN- STD GAS
Maytag CWG451 WALLOVEN- CONT CLEAN GAS
Maytag CWG4510AAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4510BAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4600AAB WALLOVEN- STD GAS
Admiral CWGA200AAB WALLOVEN- CONT CLEAN GAS
Admiral CWGA800AAB WALLOVEN- S/C GAS
Admiral CWGA800AAE WALLOVEN- S/C GAS
Frigidaire CWS3600AS0 Fs Washer - Frig/best Buy
Frigidaire CWS3600AS1 Frigidaire/washer
Frigidaire CWS445RGS0 Gib(v0) / Free Standing Washer
Frigidaire CWS445RGS1 Gib(v0) / Free Standing Washer
Maytag CX8670RB SURFACE UNIT- ELE
Maytag CX8670RV SURFACE UNIT- ELE
Maytag CX8670TB SURFACE UNIT- ELE
Maytag CX8670TV SURFACE UNIT- ELE
Maytag CX9875VVV WALLOVEN- S/C ELE
Maytag CX9875VYV WALLOVEN- S/C ELE
Maytag CX9875XYB WALLOVEN- S/C ELE
Admiral CYE1000AYW DRYER- ELE
Admiral CYE2000AKW DRYER- ELE
Magic Chef CYE2000AYA DRYER- ELE
Magic Chef CYE2000AYW DRYER- ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Oven Wont Heat to pre heat or takes a long time rmcgove Oven Repair (including Ranges and Cooktops) 0 04-23-2014 03:05 PM
the lower heat element in oven doesnt heat lickenem Oven Repair (including Ranges and Cooktops) 1 04-22-2014 04:11 AM
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 11:23 AM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
