Discuss
Retrofit Wb27T10190 Control
 in
I have a GE electric range/stove(DROP IN TYPE). the model number i listed above is correct,except maybe the 0 or
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Retrofit Wb27T10190 Control
  #1 (permalink)
Old 03-22-2017, 01:50 PM
Junior Member
stevieray2 is on a distinguished road
Smile Retrofit Wb27T10190 Control
Model Number: JMP28B0C1AD   Brand: GE   Age: More than 10 years
I have a GE electric range/stove(DROP IN TYPE). the model number i listed above is correct,except maybe the 0 or an O? but either way it has been discontinued! the oven control has bit the dust! i know it's pretty old,but i need to fix it,and everything else works,although the the front left burner(the large one) seems like you can't control the burner temperature no matter where you set it to! my main concern right now is the oven though..the Oven Control Board i have in there now is Part# WB27T10174...and the one i ordered,which is discontinued also,but i found a new one with the new wire harness and a couple of jumper wires in the kit is an Oven Control Board Part# WB27T10190.the oven control will be here Friday 3-24-2017,and from what i have gathered,is that the instructions are worthless? My QUESTION is,can someone help me with this wiring Modification?. i know the plug that comes with the new board is a 6 pin plug with one pin not used and looks like the orange and blue wires are not in the order as my old 5 pin one,but i guess that is the way the new board is configured,and i assume i have to cut my wires and splice them to the wires on the new plug,and also maybe have to add some or all of the jumper wires? i am going to have to replace the clock plate also,Part# WB27K5337 black,because my PLUS TRIANGLE button has a hole in it from someone abusing it! that's the easy part. Anyone out there that can help me with this,i would appreciate it so very much! Thanks,Stevieray
Related Models
General Electric JMP28BA1AD Electric range
General Electric JMP28BA1WH Electric range
General Electric JMP28BA2AD Electric range
General Electric JMP28BA2WH Electric range
General Electric JMP28BC1AD Electric range
General Electric JMP28BC1WH Electric range
General Electric JMP28BC2WH Electric range
General Electric JMP28BD1CT Electric range
General Electric JMP28BD2CT Electric range
General Electric JMP28BW1AD Electric range
General Electric JMP28BW1WH Electric range
General Electric JMP28BW2AD Electric range
General Electric JMP28BW2WH Electric range
General Electric JMP28GR1AD Electric range
General Electric JMP28GR1WH Electric range
General Electric JMP28GR2AD Electric range
General Electric JMP28GR2WH Electric range
General Electric JMP28GR3AD Electric range
General Electric JMP28GR3WH Electric range
General Electric JMP28GT1AD Electric range
General Electric JMP28GT1WH Electric range
General Electric JMP28GV1AD Electric range
General Electric JMP28GV1WH Electric range
General Electric JMP29GR1BK Electric range
General Electric JMP29GR2BK Electric range
General Electric JMP29GR3BK Electric range
General Electric JMP29GT1BB Electric range
General Electric JMP29GV1BB Electric range
General Electric JMP2SGR3WH ELECTRIC DROP IN RANGE
General Electric JMP31BL1BB Electric range
General Electric JMP31BL2BB ELECTRIC RANGE
General Electric JMP31CL1CC Electric range
General Electric JMP31CL2CC ELECTRIC RANGE
General Electric JMP31WA1WW Electric range
General Electric JMP31WA2WW Electric range
General Electric JMP31WC1WW Electric range
General Electric JMP31WC2WW Electric range
General Electric JMP31WC3WW ELECTRIC RANGE
General Electric JMP31WR1WH Electric range
General Electric JMP31WR2WH Electric range
General Electric JMP31WT1WW Electric range
General Electric JMP31WV1WW Electric range
General Electric JMP31WW1WW Electric range
General Electric JMP32AR1AG Electric range
Maytag JMRH2 JADE MODULAR OPEN BURNER (COOKING GAS)
Maytag JMRH2A JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRH36B COMMERCIAL COOKING
 JMRH36GT COMMERCIAL COOKING
Maytag JMRH4 JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRH48GT COMMERCIAL COOKING
Maytag JMRH4A JADE MODULAR OPEN BURNER (COOKING GAS)
Maytag JMRH6 JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRHE33 COMMERCIAL COOKING
General Electric JMS07*J1 Electric range
General Electric JMS07*J2 Electric range
General Electric JMS07*J3 Electric range
General Electric JMS07*J4 Electric range
General Electric JMS07*J5 Electric range
General Electric JMS070J3 ELECTRIC DROP-IN RANGES
General Electric JMS07G*P1 Electric range
General Electric JMS07J4 ELECTRIC DROP-IN RANGE
General Electric JMS07J5 27" DROP IN ELECTRIC RANGE
General Electric JMS08BA1AD Electric range
General Electric JMS08BA1WH Electric range
General Electric JMS08BA2AD Electric range
General Electric JMS08BA2WH Electric range
General Electric JMS08BD1AD Electric range
General Electric JMS08BD1WH Electric range
General Electric JMS08BD2CT Electric range
General Electric JMS08BD2WH Electric range
General Electric JMS08BD3CT Electric range
General Electric JMS08BD3WH Electric range
General Electric JMS08BW1AD Electric range
General Electric JMS08BW1WH Electric range
General Electric JMS08BW2AD Electric range
General Electric JMS08BW2WH Electric range
General Electric JMS08GR1AD Electric range
General Electric JMS08GR1WH Electric range
General Electric JMS08GR2AD Electric range
General Electric JMS08GR2WH Electric range
General Electric JMS08GT1AD Electric range
General Electric JMS08GT1WH Electric range
General Electric JMS08GV1AD Electric range
General Electric JMS08GV1WH Electric range
General Electric JMS10GR1AD Electric range
General Electric JMS10GR1WH Electric range
General Electric JMS10GR2AD Electric range
General Electric JMS10GR2WH Electric range
General Electric JMS27G*01 GE FREE-STANDING / DROP-
General Electric JMS27G*H1 Electric range
General Electric JMS27G*J1 Electric range
General Electric JMS27G*J2 Electric range
General Electric JMS27G*J3 Electric range
General Electric JMS27G*J4 Electric range
General Electric JMS27G0J3 ELECTRIC DROP-IN RANGE
General Electric JMS27GJ4 ELECTRIC DROP-IN RANGE
General Electric JMT10F01 Electric range
General Electric JMT11F01 Electric range
General Electric JMT1901 Electric range
General Electric JMT19F01 Electric range
General Electric JMT2001 Electric range
General Electric JMT20F01 Electric range
Jenn-Air JMV8000ADB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000ADW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDW MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAB MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8166BAB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8166BAS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8166BAW MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8186AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAB14 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wb27t10190 jwciii Oven Repair (including Ranges and Cooktops) 5 11-17-2012 10:56 AM
microwave exhaust retrofit ameren Microwave Repair 0 02-11-2012 10:41 AM
Retrofit mechanical timer adamt Dishwasher Repair 1 04-02-2010 04:40 PM
Trying to wire up GE oven control WB27T10190 Mr. Pogi Oven Repair (including Ranges and Cooktops) 1 10-25-2008 11:55 AM
Retrofit oven control e larson Oven Repair (including Ranges and Cooktops) 4 02-28-2008 02:44 PM
