Discuss
baking element
 in
my baking element went out on my stove. changed element. replaced connectors for the element, still nothing,everything else works. so
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » baking element
  #1 (permalink)
Old 03-15-2017, 08:10 AM
Junior Member
mpd038 is on a distinguished road
Default baking element
Model Number: TEF326FBC   Brand: Tappan   Age: 5 - 10 years
my baking element went out on my stove. changed element. replaced connectors for the element, still nothing,everything else works. so now ordering control panel, when turning it on to bake the broiler heats but baking element stays cold as ice. any other suggestions
Related Models
Tappan TEF326FBC ELECTRIC RANGE
Tappan TEF326FSA Tappan/range
Tappan TEF326FSB ELECTRIC RANGE
Tappan TEF326FSC ELECTRIC RANGE
Tappan TEF326FSD ELECTRIC RANGE
Tappan TEF326FSE ELECTRIC RANGE
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Tappan TEF351EWD ELECTRIC RANGE
Tappan TEF351EWE ELECTRIC RANGE
Tappan TEF351EWF ELECTRIC RANGE
Tappan TEF351EWG ELECTRIC RANGE
Tappan TEF351EWH ELECTRIC RANGE
Tappan TEF351EWJ TAPPAN/ELECTRIC RANGE
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
Tappan TEF353AQE Tappan/range
Tappan TEF353AQF Tappan/electric Range
Tappan TEF353ASA Tappan/range
Tappan TEF353ASB Tappan/electric Range
Tappan TEF353ASC Tappan/electric Range
Tappan TEF353ASD Tappan/electric Range
Tappan TEF353ASE Tappan/range
Tappan TEF353ASF Tappan/electric Range
Tappan TEF353AUA Tappan/range
Tappan TEF353AUB Tappan/electric Range
Tappan TEF353AUC Tappan/electric Range
Tappan TEF353AUD Tappan/electric Range
Tappan TEF353AUE Tappan/range
Tappan TEF353AUF Tappan/electric Range
Tappan TEF353AWA Tappan/range
Tappan TEF353AWB Tappan/electric Range
Tappan TEF353AWC Tappan/electric Range
Tappan TEF353AWD Tappan/electric Range
Tappan TEF353AWE Tappan/range
Tappan TEF353AWF Tappan/electric Range
Frigidaire TEF354BCDA Tap(v1) / Electric Range
Frigidaire TEF354BCDB Tap(v1) / Electric Range
Frigidaire TEF354BCDC Tap(v1) / Electric Range
Frigidaire TEF354BCDD Tap(v1) / Electric Range
Frigidaire TEF354BCWA Tap(v2) / Electric Range
Frigidaire TEF354BCWB Tap(v2) / Electric Range
Frigidaire TEF354BCWC Tap(v2) / Electric Range
Frigidaire TEF354BCWD Tap(v2) / Electric Range
Frigidaire TEF355BCDA Tap(v1) / Electric Range
Frigidaire TEF355BCDB Tap(v1) / Electric Range
Frigidaire TEF355BCDC Tap(v1) / Electric Range
Frigidaire TEF355BCWA Tap(v2) / Electric Range
Frigidaire TEF355BCWB Tap(v2) / Electric Range
Frigidaire TEF355BCWC Tap(v2) / Electric Range
Frigidaire TEF355BFDA Tap(v1) / Electric Range
Frigidaire TEF355BFWA Tap(v2) / Electric Range
Frigidaire TEF355BXDA Tap(v3) / Electric Range
Frigidaire TEF355BXWA Tap(v4) / Electric Range
Frigidaire TEF356SCWA Tap(v0) / Electric Range
Frigidaire TEF356SCWB Tap(v0) / Electric Range
Frigidaire TEF356SCWC Tap(v0) / Electric Range
Frigidaire TEF356SCWD Tap(v0) / Electric Range
Frigidaire TEF357BCDA Tap(v1) / Electric Range
Frigidaire TEF357BCDB Tap(v1) / Electric Range
Frigidaire TEF357BCDC Tap(v1) / Electric Range
Frigidaire TEF357BCDD Tap(v1) / Electric Range
Frigidaire TEF357BCDE Tap(v1) / Electric Range
Frigidaire TEF357BCWA Tap(v2) / Electric Range
Frigidaire TEF357BCWB Tap(v2) / Electric Range
Frigidaire TEF357BCWC Tap(v2) / Electric Range
Frigidaire TEF357BCWD Tap(v2) / Electric Range
Frigidaire TEF357BCWE Tap(v2) / Electric Range
Frigidaire TEF357BFDA Tap(v1) / Electric Range
Frigidaire TEF357BFDB Tap(v1) / Electric Range
Frigidaire TEF357BFWA Tap(v2) / Electric Range
Frigidaire TEF357BFWB Tap(v2) / Electric Range
Tappan TEF360MXDSA Tappan/electric Range
Tappan TEF360MXDSE Tappan/electric Range
Tappan TEF360MXDSF Tappan/electric Range
Tappan TEF360MXDSG Tappan/range
Tappan TEF361ESA Tappan/range
Tappan TEF361ESB Tappan/range
Tappan TEF361ESC Tappan/range
Tappan TEF361ESD Tappan/electric Range
Tappan TEF361ESE ELECTRIC RANGE
Tappan TEF361ESF Tappan/range
Tappan TEF361GSA ELECTRIC RANGE
Tappan TEF361GSB ELECTRIC RANGE
Tappan TEF361GSD ELECTRIC RANGE
Frigidaire TEF362BBBA Tap(v0) / Electric Range
Frigidaire TEF362BBBB Tap(v0) / Electric Range
Frigidaire TEF362BBBC Tap(v0) / Electric Range
  #2 (permalink)
Old 03-15-2017, 11:32 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
It sounds like you are on the right track. Its probably a relay on the microcomputer/oven control.
Just make sure all of your connections fit together snugly. Loose connections generate heat and fail.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
baking element and broiler element not working davidmb Oven Repair (including Ranges and Cooktops) 1 10-03-2014 05:57 AM
baking element tilly Oven Repair (including Ranges and Cooktops) 0 05-11-2014 10:20 AM
baking element cander11 Oven Repair (including Ranges and Cooktops) 0 08-25-2011 04:33 PM
no baking after new element drush Oven Repair (including Ranges and Cooktops) 0 01-25-2010 10:29 AM
Baking Element koch35 Oven Repair (including Ranges and Cooktops) 1 01-07-2009 08:20 PM
