Discuss
Need hehp with Jenn Air 2-wire fan switch wiring
 in
Hello, I need help with wiring the downdraft fan switch. This switch is for C221 Jenn-Air electric cook-top that has
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Need hehp with Jenn Air 2-wire fan switch wiring
  #1 (permalink)
Old 03-06-2017, 09:46 AM
psk psk is offline
Junior Member
psk is on a distinguished road
Default Need hehp with Jenn Air 2-wire fan switch wiring
Model Number: C221   Brand: Jenn-Air   Age: More than 10 years
Hello, I need help with wiring the downdraft fan switch. This switch is for C221 Jenn-Air electric cook-top that has two wires for the downdraft fan. The fan was working before I tried to replace one of the infinite switches below the fan switch. I must have accidentally touched one of the fan wires while replacing the infinite switch. The wire which is attached to the left terminal of the fan switch is hanging in the air and I do not know where it should be connected to. The other wire (Black) which is attached to the center/right terminal is still connected to the motor below. The disconnected wire has a hook at the end of the crimp and I feel that it can be piggy bagged onto some other wire, but I just do not know which one. Could someone help, please?
Related Models
Jenn-Air C221 SURFACE UNIT- DDRAFT ELE
Jenn-Air C221-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C221-J SURFACE UNIT- DDRAFT ELE
Amana C221DW FREEZER- CHEST
Amana C221FW FREEZER- CHEST
Jenn-Air C222 SURFACE UNIT- DDRAFT ELE
Roper C2257*0 GAS COOKTOP
Roper C2257W0 GAS COOKTOP
Jenn-Air C226 SURFACE UNIT- DDRAFT ELE
Jenn-Air C226W-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C228 SURFACE UNIT- DDRAFT ELE
Jenn-Air C228B-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C228W SURFACE UNIT- DDRAFT ELE
Jenn-Air C228W-C SURFACE UNIT- DDRAFT ELE
Amana C22B3W FREEZER- CHEST
Maytag C22HS FREEZER- CHEST
Maytag C22J FREEZER- CHEST
Roper C2357*0 GAS COOKTOP
Roper C2357W0 GAS COOKTOP
Jenn-Air C236 SURFACE UNIT- DDRAFT ELE
Jenn-Air C236-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C236B SURFACE UNIT- DDRAFT ELE
Jenn-Air C236B-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C236B-E SURFACE UNIT- DDRAFT ELE
Jenn-Air C236NGB SURFACE UNIT- DDRAFT ELE
Jenn-Air C236NGW SURFACE UNIT- DDRAFT ELE
Jenn-Air C236W SURFACE UNIT- DDRAFT ELE
Jenn-Air C236W-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C236W-E SURFACE UNIT- DDRAFT ELE
Jenn-Air C238 SURFACE UNIT- DDRAFT ELE
Jenn-Air C238B-C SURFACE UNIT- DDRAFT ELE
Amana C23B FREEZER- CHEST
Amana C23B-1 FREEZER- CHEST
Amana C23B-1-A FREEZER- CHEST
Amana C23B-1-C FREEZER- CHEST
Amana C23B-1-G FREEZER- CHEST
Amana C23B-1-L FREEZER- CHEST
Amana C23B-A FREEZER- CHEST
Amana C23B-C FREEZER- CHEST
Amana C23B-G FREEZER- CHEST
Amana C23B-L FREEZER- CHEST
Amana C23B1 FREEZER- CHEST
Amana C23B1L FREEZER- CHEST
Amana C23F FREEZER- CHEST
Amana C23F Freezer - Chest
Amana C23F-A FREEZER- CHEST
Amana C23F-AG FREEZER- CHEST
Amana C23F-C FREEZER- CHEST
Amana C23W FREEZER- CHEST
Amana C23W-A FREEZER- CHEST
Amana C23W-AG FREEZER- CHEST
Amana C23W-C FREEZER- CHEST
Roper C2557*0 GAS COOKTOP
Roper C2557W0 GAS RANGE
Maytag C25AALWH FREEZER- CHEST
Maytag C25ABLWH FREEZER- CHEST
Maytag C25ACLWH FREEZER- CHEST
Maytag C25ADLWH FREEZER- CHEST
Maytag C25D FREEZER- CHEST
Thermador C271U BUILT-IN OVENS
Thermador C272U BUILT-IN OVENS
Roper C2757*0 GAS COOKTOP
Roper C2757W0 GAS COOKTOP
Amana C28B FREEZER- CHEST
Amana C28B-1 FREEZER- CHEST
Amana C28B-1-A FREEZER- CHEST
Amana C28B-1-C FREEZER- CHEST
Amana C28B-1-G FREEZER- CHEST
Amana C28B-1-L FREEZER- CHEST
Amana C28B-A FREEZER- CHEST
Amana C28B-C FREEZER- CHEST
Amana C28B-G FREEZER- CHEST
Amana C28B-L FREEZER- CHEST
Amana C28B1 FREEZER- CHEST
Amana C28B1L FREEZER- CHEST
Amana C28F FREEZER- CHEST
  #2 (permalink)
Old 03-08-2017, 11:20 AM
psk psk is offline
Junior Member
Default I fixed the problem
I found that the disconnected wire needs to be connected/piggy bagged onto one of the wires of the infinite switch. Once it was connected, the fan worked.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air Infinte switch Wiring Suzzz Oven Repair (including Ranges and Cooktops) 0 03-13-2014 01:05 PM
SEG196-Wiring a two wire replacement switch ??? Alan Gerew Oven Repair (including Ranges and Cooktops) 2 05-07-2013 03:40 PM
Jenn-Air Infinite switch wiring to next switch jb63129 Oven Repair (including Ranges and Cooktops) 1 10-25-2010 07:09 AM
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 5 11-24-2009 02:14 PM
