Hello, I just purchased this stove used but the center burner does not operate as it should. It will burn normally at mid range settings but when on high the flame blows out on some portions of the burner. On the lowest setting the flame will out. I have tried to use the adjustment in the stem but I do not see any change. The rest of the burners seem to function as they should. Any ideas on what to look for?
Thanks!
