Turned on right front range burner, caused breaker to engage. Reset, turned on left front, spark and smoke appeared at back of stove, probably near spark module, breaker engaged. Reset, nothing happens. Electricity flowing to rest of stove.
Obviously the spark module is gone, and I have ordered a replacement thru you guys. I wonder now, could a faulty igniter have caused the spark module to fail? Is there a chance I will replace the (pricey) spark module, and have it instantly fail due to a bad igniter?
Will one bad igniter cause others to short? If not, that would point to the spark module as the culprit, correct? Not sure what to do next.
