Discuss
Kitchenaid Double Wall - Top won't come to temp
 in
Trying to trouble shoot my oven problem. The top oven comes on and starts to heat up but will not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchenaid Double Wall - Top won't come to temp
  #1 (permalink)
Old 02-27-2017, 06:58 PM
Junior Member
JWT66 is on a distinguished road
Default Kitchenaid Double Wall - Top won't come to temp
Model Number: KEBS208SSS   Brand: Kitchen Aid   Age: 1 - 5 years
Trying to trouble shoot my oven problem. The top oven comes on and starts to heat up but will not come all the way up to the set temp. It just stops heating and sits there cooling down. No error codes or sounds, just stops. Reset it for a higher temp and it comes back on and starts to heat again, then stalls out. The bottom oven works as normal.
I thought it could be the temp probe so I switched top and bottom probes, no change. Bottom still works good, top still stalls. I now assume it is the control panel but am realizing there are 2 different control panel parts in there. W10312205 and W10119142. If they were cheap I would take a chance, but for the cost of them I would like to hit the right one. I can't find any way to diagnose, so I thought I would check in here for thoughts. Being as the bottom works would it indicate that one of these boards has to be good and point at the other one?
Any advice appreciated.
John
Related Models
Whirlpool KEBS208SSS00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SSS02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SSS03 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SWH00 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SWH02 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
Whirlpool KEBS208SWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION
KitchenAid KEBS227BAL0 27" ELEC DOUBLE OVEN - CONVECTION
Whirlpool KEBS245SBL0 ELECTRIC RANGES & OVENS
Whirlpool KEBS245SBL1 Ranges, Electric*
Whirlpool KEBS246BBL0 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS246BBL1 24" BUILT-IN DOUBLE OVEN
Whirlpool KEBS246BBL2 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS246BBL3 24" BUILT-IN DOUBLE OVEN
Whirlpool KEBS246BWH0 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS246BWH1 24" BUILT-IN DOUBLE OVEN
Whirlpool KEBS246BWH2 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS246BWH3 24" BUILT-IN DOUBLE OVEN
Whirlpool KEBS246SBL1 24" BUILT-IN SELF-CLEAN ELECTRIC OVEN
Whirlpool KEBS246SBL2 24" ELECTRIC BUILT-IN OVEN
Whirlpool KEBS246WBL0 Ranges, Electric*
Whirlpool KEBS246WBL1 Ranges, Electric*
Whirlpool KEBS246WBL2 Ranges, Electric*
Whirlpool KEBS246WBL3 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS246XBL0 Ranges, Electric*
Whirlpool KEBS246XBL2 Ranges, Electric*
Whirlpool KEBS246XBL3 Ranges, Electric*
Whirlpool KEBS246YBL0 ELEC BUILT-IN OVEN--DBL
Whirlpool KEBS246YBL1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS246YBL2 ELEC BUILT-IN OVEN-DBL
Whirlpool KEBS246YBL3 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS246YBL4 ELECTRIC BUILT IN OVEN - DBL
Whirlpool KEBS246YWH0 ELEC BUILT-IN OVEN--DBL
Whirlpool KEBS246YWH1 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS246YWH3 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS246YWH4 ELECTRIC BUILT IN OVEN - DBL
Whirlpool KEBS247DBL1 Built-In Oven, Electric
Whirlpool KEBS247DBL10 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS247DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS247DBL12 OVEN
Whirlpool KEBS247DBL2 Built-In Oven, Electric
Whirlpool KEBS247DBL4 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS247DBL6 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS247DBL7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS247DBL8 ELECTRIC WALL OVEN
Whirlpool KEBS247DBL9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS247DWH1 Built-In Oven, Electric
Whirlpool KEBS247DWH10 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS247DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS247DWH12 OVEN
Whirlpool KEBS247DWH2 Built-In Oven, Electric
Whirlpool KEBS247DWH4 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS247DWH6 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS247DWH7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS247DWH8 ELECTRIC WALL OVEN
Whirlpool KEBS247DWH9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS276BBL0 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS276BBL1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS276BBL2 27" BUILT-IN DOUBLE OVEN
Whirlpool KEBS276BBL3 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS276BWH0 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS276BWH1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS276BWH2 27" BUILT-IN DOUBLE OVEN
Whirlpool KEBS276BWH3 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool KEBS276SBL0 Ranges, Electric*
Whirlpool KEBS276SBL1 Ranges, Electric*
Whirlpool KEBS276SBL2 Ranges, Electric*
Whirlpool KEBS276SBL3 ELECTRIC RANGE
Whirlpool KEBS276WBL0 Ranges, Electric*
Whirlpool KEBS276WBL1 Ranges, Electric*
Whirlpool KEBS276WBL2 Ranges, Electric*
Whirlpool KEBS276WBL3 Ranges, Electric*
KitchenAid KEBS276WWH3 Ranges, Electric*
Whirlpool KEBS276XBL0 Ranges, Electric*
Whirlpool KEBS276XBL2 Ranges, Electric*
Whirlpool KEBS276XBL3 Ranges, Electric*
Whirlpool KEBS276YBL0 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS276YBL1 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS276YBL2 ELEC BUILT-IN DBL OVEN
Whirlpool KEBS276YBL3 ELEC BUILT IN DBL OVEN
Whirlpool KEBS276YBL4 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS276YWH0 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS276YWH1 ELEC BUILT-IN OVEN - DBL
Whirlpool KEBS276YWH3 ELEC BUILT IN DBL OVEN
Whirlpool KEBS276YWH4 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS277BAL0 27" BUILT-IN DOUBLE OVEN
Whirlpool KEBS277BAL1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS277BAL2 27" BUILT-IN ELEC DOUBLE OVEN
Whirlpool KEBS277BAL3 27" BUILT-IN DOUBLE OVEN
Whirlpool KEBS277BBL0 27" ELEC DOUBLE OVEN - CONVECTION
Whirlpool KEBS277BBL1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS277BBL2 27" BUILT-IN ELEC DOUBLE OVEN
Whirlpool KEBS277BBL3 27" BUILT-IN DOUBLE OVEN
Whirlpool KEBS277BWH0 27" ELEC DOUBLE OVEN - CONVECTION
Whirlpool KEBS277BWH1 ELECTRIC BUILT-IN DOUBLE OVEN
Whirlpool KEBS277BWH2 27" BUILT-IN ELEC DOUBLE OVEN
Whirlpool KEBS277BWH3 27" BUILT-IN DOUBLE OVEN
Whirlpool KEBS277DAL1 OVEN STOPS WORKING MID-CYCLE-DOUBLE OVENS
Whirlpool KEBS277DAL2 OVEN STOPS WORKING MID-CYCLE-DOUBLE OVENS
Whirlpool KEBS277DAL4 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DAL6 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBL1 Built-In Oven, Electric
Whirlpool KEBS277DBL10 BUILT IN OVEN, ELECTRIC
Whirlpool KEBS277DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS277DBL12 OVEN
Whirlpool KEBS277DBL2 Built-In Oven, Electric
KitchenAid KEBS277DBL3 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBL4 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBL6 27" BUILT-IN ELECTRIC WALL OVEN
Whirlpool KEBS277DBL7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS277DBL8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBL9 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBT10 BUILT IN OVEN, ELECTRIC
Whirlpool KEBS277DBT11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBS277DBT12 OVEN
Whirlpool KEBS277DBT6 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBT7 BUILT - IN ELECTRIC OVEN
Whirlpool KEBS277DBT8 BUILT-IN ELECTRIC OVEN
Whirlpool KEBS277DBT9 BUILT-IN ELECTRIC OVEN
KitchenAid KEBS277DHW2 27" BUILT-IN ELECTRIC OVEN
  #2 (permalink)
Old 05-07-2017, 06:45 PM
Junior Member
Default
Any thoughts on this before I flip a coin on these 2 parts?
Any advice appreciated. John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid wall mounted double oven rrutecky Oven Repair (including Ranges and Cooktops) 0 12-13-2016 06:03 PM
KitchenAid Double Wall Oven Leo Ladzinske Oven Repair (including Ranges and Cooktops) 5 01-07-2016 02:43 AM
Kitchenaid double wall oven not working lakedweller Oven Repair (including Ranges and Cooktops) 0 12-06-2013 09:21 AM
U34 Temp Sensor Dacor Double Wall Ovens Mitch409 Oven Repair (including Ranges and Cooktops) 0 01-19-2011 12:32 PM
Kitchenaid Double Wall Oven Error E1-F2 iraslotnick Oven Repair (including Ranges and Cooktops) 14 12-17-2008 08:49 PM
