Discuss
NOT while the oven is on, the control panel turns off unpredictably
 in
The control panel shuts off at random times, often in the evening, for a few minutes at a time, sometimes
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » NOT while the oven is on, the control panel turns off unpredictably
  #1 (permalink)
Old 02-26-2017, 10:01 AM
Junior Member
Sheiretov is on a distinguished road
Default NOT while the oven is on, the control panel turns off unpredictably
Model Number: ARGS7650SS   Brand: Amana   Age: More than 10 years
The control panel shuts off at random times, often in the evening, for a few minutes at a time, sometimes longer, the clock resets, etc. as if the power was shut down. I don't think it has ever happened while the oven is on though, so I think I must rule out that the overtemperature switch is engaging too soon. Perhaps it is bad anyway or maybe there is a bad connection somewhere else. I have two questions:
1) Is there a very likely part that is bad that I should check first?
2) What is the best way to get to the temperature switches and to the control panel wiring? I was unable to find good instructions on how to take the top off. On this model, the panel is right above the oven. Are there instructions on how to open up the range?
The "P" number is P1130765NSS
By the way I keep reading that these ranges have fans but I have never heard one come on.
Thanks for your help!
Yanko
Related Models
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Amana ARHC8700WW RANGE- S/C F/S ELE
Amana ARHSC8750E RANGE- S/C S/I DDRAFT ELE
Amana ARHSC8750WW RANGE- S/C S/I DDRAFT ELE
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L RANGE- S/C S/I DDRAFT GAS
Amana ARO3100W RANGE- S/C S/I DDRAFT GAS
Amana ARO3400L RANGE- S/C S/I DDRAFT GAS
Amana ARO3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR-201 RANGE- S/C S/I DDRAFT ELE
Amana ARR-201 RANGE- S/C S/I DDRAFT GAS
Amana ARR-401 RANGE- S/C S/I DDRAFT ELE
Amana ARR-401 RANGE- S/C S/I DDRAFT GAS
Amana ARR-402 RANGE- S/C S/I DDRAFT ELE
Amana ARR-402 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT ELE
Amana ARR-412 RANGE- S/C S/I DDRAFT ELE
Amana ARR-415 RANGE- S/C S/I DDRAFT ELE
Amana ARR101W RANGE- S/C S/I DDRAFT ELE
Amana ARR301 RANGE- S/C S/I DDRAFT ELE
Amana ARR301W RANGE- S/C S/I DDRAFT ELE
Amana ARR303 RANGE- S/C S/I DDRAFT ELE
Amana ARR303W RANGE- S/C S/I DDRAFT ELE
Amana ARR305 RANGE- S/C S/I DDRAFT ELE
Amana ARR3100L RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NL RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NW RANGE- S/C S/I DDRAFT GAS
Amana ARR3100W RANGE- S/C S/I DDRAFT GAS
Amana ARR3400L RANGE- S/C S/I DDRAFT GAS
Amana ARR3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR3601LL Range - S/c S/i Ddraft Gas
Amana ARR3601LL RANGE- S/C S/I DDRAFT GAS
Amana ARR3601WW Range - S/c S/i Ddraft Gas
Amana ARR3601WW RANGE- S/C S/I DDRAFT GAS
Amana ARR5200L RANGE- STD MWAVE ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas oven & display panel turns off when heating oven, recovers when cool Byrdson Oven Repair (including Ranges and Cooktops) 1 02-07-2017 12:03 PM
Amana Gas Range turns off unpredictably Ray Theon Oven Repair (including Ranges and Cooktops) 38 10-15-2016 02:36 PM
GE Range turns off after 30 seconds and some keys on digital control panel don't work berryszoo Oven Repair (including Ranges and Cooktops) 0 07-20-2013 11:36 AM
Kenmore Gas Oven Control Panel Shuts & Resets Itself Unpredictably soosweet Oven Repair (including Ranges and Cooktops) 0 08-21-2011 10:22 PM
Oven control panel fritzing out (turns oven back on!) mcuth Oven Repair (including Ranges and Cooktops) 0 05-20-2011 09:05 AM
