This stove developed a problem where the 2 right side burners would not work at all. Before they finally died they would barely work and sometimes turning on one would cause the other one to heat up a little.
I pulled the 2 burner assembly from the receptacle in the main stove body and noticed one of the contact spades was burnt looking. I ordered this part and replaced it. One burner would then work but not the other one. I then thought I needed to replace the receptacle the burner goes in. I ordered that part and replaced it. Now the burner comes on, but it does not reach full heat.
Where do I go next? I am at a loss on what to do next.
