Discuss
Weird Temp Sensor issue
 in
Strange issue with the temperature sensor: the oven temperature has been higher than set for a while (set oven to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Weird Temp Sensor issue
  #1 (permalink)
Old 02-21-2017, 07:12 AM
Junior Member
YooHoo is on a distinguished road
Default Weird Temp Sensor issue
Model Number: ARG7600   Brand: Amana   Age: More than 10 years
Strange issue with the temperature sensor: the oven temperature has been higher than set for a while (set oven to 375, it holds steady at 450, etc.)/ Recently it just refused to run at all, showing an F3 error.
So I pulled the temp sensor and checked resistance. It was a completely open circuit (infinite resistance on every scale).
I'm just confused because it seems to me that if the sensor was underreporting the temperature, that would mean too little resistance, right? And so I'd expect it to eventually fail to a shorted circuit or at any rate way too little resistance. Is it reasonable to expect it to fail to open circuit, or am I just not getting a good reading with my multimeter?
Related Models
Amana ARG7600CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C F/S GAS
Amana ARG7600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7600W RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C F/S GAS
Amana ARG7800CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7800E RANGE- S/C S/I DDRAFT GAS
Amana ARG7800LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7800SS RANGE- S/C S/I DDRAFT GAS
Amana ARG7800WW RANGE- S/C S/I DDRAFT GAS
Amana ARGS7650CC RANGE- S/C S/I GAS
Amana ARGS7650E RANGE- S/C S/I GAS
Amana ARGS7650LL RANGE- S/C S/I GAS
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
  #2 (permalink)
Old 02-21-2017, 09:04 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
The oven sensors usually fail open or shorted.
In Amanas, F3 is an open or shorted temperature probe.
  #3 (permalink)
Old 02-21-2017, 12:52 PM
Junior Member
Default
Thanks, ThatGuy. What was confusing was that the probe seemed to have been giving too low a resistance (as the actual oven temperature was higher than set), so I would have expected it to keep progressively moving toward completely shorted. But it seems to be completely open now, which is the opposite direction.
Just wondering if this situation (resistance too low > failed open) was reasonable to expect, or should I assume I haven't gotten a good resistance reading?
  #4 (permalink)
Old 02-21-2017, 04:15 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Here's a chart. Higher resistance = higher temp.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KitchenAid Washer Weird Issue -Electrical? zee652 Washer Repair 9 04-09-2013 06:59 PM
weird issue with bolt djmceltic Washer Repair 0 06-25-2012 03:48 PM
Amana Range - Weird power issue jpmi23 Oven Repair (including Ranges and Cooktops) 22 10-12-2011 05:21 AM
Gas range - weird smell, temp not right elisedavies21 Oven Repair (including Ranges and Cooktops) 0 11-24-2008 10:15 AM
Temp inaccurate and weird warnings rbmanrow Oven Repair (including Ranges and Cooktops) 1 02-06-2008 05:38 PM
