I have a very old, but functional Crown stove. It has two ovens, side by side. Each one has a problem. One won't light (I started a different thread about that one), while the other has a door that won't close tightly. As a result, a lot of heat escapes and food does not cook evenly. I can't use the other oven because it won't light.
I tried to see what the problem might be, but with no luck. I don't think the door is the type to pull up and out. I looked under the oven for screws or something to remove the door, but couldn't see anything there either. I have no idea how to even check for what the problem is let alone fix it.
Anyone have an idea on where I might start?
