Discuss
F5 error code Maytag electric wall oven
 in
F5 error code and beeping in Maytag electric wall oven model CWE9000BCE, serial # 13751215KS, approx 22 years old. What
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F5 error code Maytag electric wall oven
  #1 (permalink)
Old 02-01-2017, 12:36 PM
Junior Member
trafficjam is on a distinguished road
Question F5 error code Maytag electric wall oven
Model Number: CWE9000BCE   Brand: Maytag   Age: More than 10 years
What does F5 mean in this model oven? I have been unable to locate a repair manual so I don't know what this code means.
Symptoms:
When I try to heat up the oven to bake something, the oven behaves correctly for about 10 seconds. I hear a little click and a fan starts whirring. The current temp registers on the screen. But the lower heating element does not start glowing. Within 30-40 seconds, the process shuts down, the oven starts beeping and flashing F5 on the screen.
Problem is intermittent. It happens nearly 100% of the time, but not quite. After happening several times today, the problem suddenly resolved and the unit is working properly now -- for the moment. This is the first time in over a month that the oven has worked when I try to bake something.
Broiler function seems ok. No error code there. At least not right now. I don't recall whether I tested that function before today.
Related Models
Maytag CWE9000BCE WALLOVEN- S/C ELE
Maytag CWE9000BCM WALLOVEN- S/C ELE
Maytag CWE9000BDB WALLOVEN- S/C ELE
Maytag CWE9000BDE WALLOVEN- S/C ELE
Maytag CWE9000CDB WALLOVEN- S/C ELE
Maytag CWE9000CDE WALLOVEN- S/C ELE
Maytag CWE9000DDB WALLOVEN- S/C ELE
Maytag CWE9000DDE WALLOVEN- S/C ELE
Maytag CWE9030BCB WALLOVEN- S/C ELE
Maytag CWE9030BCE WALLOVEN- S/C ELE
Maytag CWE9030BDB WALLOVEN- S/C ELE
Maytag CWE9030BDE WALLOVEN- S/C ELE
Maytag CWE9030DDB WALLOVEN- S/C ELE
Maytag CWE9030DDE WALLOVEN- S/C ELE
Maytag CWE9900 WALLOVEN- S/C ELE
Admiral CWEA100ACB WALLOVEN- STD ELE
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF310GSA ELECTRIC RANGE
White Westinghouse CWEF310GSB ELECTRIC RANGE
White Westinghouse CWEF310GSC ELECTRIC RANGE
White Westinghouse CWEF310GSD ELECTRIC RANGE
White Westinghouse CWEF310GSE ELECTRIC RANGE
White Westinghouse CWEF310GSF ELECTRIC RANGE
White Westinghouse CWEF311ES1 White Westinghouse/electric Range
White Westinghouse CWEF312ES1 Ww Canada/electric Range
White Westinghouse CWEF312FSA Ww Canada/electric Range
White Westinghouse CWEF312FSB White Westinghouse/range
White Westinghouse CWEF312GSA ELECTRIC RANGE
White Westinghouse CWEF312GSB ELECTRIC RANGE
White Westinghouse CWEF320ES1 Whiet Westinghouse Canada/electric Range
White Westinghouse CWEF322ES1 Ww Canada/electric Range
White Westinghouse CWEF322ES3 W - W Canada/electric Range
White Westinghouse CWEF322ES4 Ww Canada/electric Range
White Westinghouse CWEF322ES5 Ww Canada/electric Range
White Westinghouse CWEF355ES1 White Westinghouse/electric Range
Maytag CWG300 WALLOVEN- STD GAS
Maytag CWG301 WALLOVEN- STD GAS
Maytag CWG302 WALLOVEN- STD GAS
Maytag CWG3020AAB WALLOVEN- STD GAS
Maytag CWG3020AAE WALLOVEN- STD GAS
Maytag CWG3020BAB WALLOVEN- STD GAS
Maytag CWG3020BAE WALLOVEN- STD GAS
Maytag CWG3100AAB WALLOVEN- STD GAS
Maytag CWG3100AAB25 24" BUILT-IN GAS OVEN
Maytag CWG3100AAE WALLOVEN- STD GAS
Maytag CWG3100AAE29 24" BUILT-IN GAS OVEN
Maytag CWG3100AAS WALLOVEN- STD GAS
Maytag CWG3100AAS13 24" BUILT-IN GAS OVEN
Maytag CWG351 WALLOVEN- STD GAS
Maytag CWG3510AAB WALLOVEN- STD GAS
Maytag CWG3510BAB WALLOVEN- STD GAS
Maytag CWG3600AAB WALLOVEN- STD GAS
Maytag CWG3600AAB26 24" BUILT-IN GAS OVEN
Maytag CWG3600AAS WALLOVEN- STD GAS
Maytag CWG3600AAS13 24" BUILT-IN GAS OVEN
Maytag CWG400 WALLOVEN- STD GAS
Maytag CWG401 WALLOVEN- STD GAS
Maytag CWG402 WALLOVEN- CONT CLEAN GAS
Maytag CWG4020AAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4020BAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4100AAB WALLOVEN- STD GAS
Maytag CWG450 WALLOVEN- STD GAS
Maytag CWG451 WALLOVEN- CONT CLEAN GAS
Maytag CWG4510AAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4510BAB WALLOVEN- CONT CLEAN GAS
Maytag CWG4600AAB WALLOVEN- STD GAS
Admiral CWGA200AAB WALLOVEN- CONT CLEAN GAS
Admiral CWGA800AAB WALLOVEN- S/C GAS
Admiral CWGA800AAE WALLOVEN- S/C GAS
Frigidaire CWS3600AS0 Fs Washer - Frig/best Buy
Frigidaire CWS3600AS1 Frigidaire/washer
Frigidaire CWS445RGS0 Gib(v0) / Free Standing Washer
Frigidaire CWS445RGS1 Gib(v0) / Free Standing Washer
Maytag CX8670RB SURFACE UNIT- ELE
Maytag CX8670RV SURFACE UNIT- ELE
Maytag CX8670TB SURFACE UNIT- ELE
Maytag CX8670TV SURFACE UNIT- ELE
Maytag CX9875VVV WALLOVEN- S/C ELE
Maytag CX9875VYV WALLOVEN- S/C ELE
Maytag CX9875XYB WALLOVEN- S/C ELE
Admiral CYE1000AYW DRYER- ELE
Admiral CYE2000AKW DRYER- ELE
Magic Chef CYE2000AYA DRYER- ELE
Magic Chef CYE2000AYW DRYER- ELE
Magic Chef CYE2000AZW DRYER- ELE
Admiral CYE3004AGW DRYER- ELE
Admiral CYE3004AKW DRYER- ELE
Magic Chef CYE3004AYW DRYER- ELE
Magic Chef CYE3004AZW DRYER- ELE
Admiral CYE3005AGW DRYER- ELE
Magic Chef CYE3005AKW DRYER- ELE
Magic Chef CYE3005AYW DRYER- ELE
Magic Chef CYE3005AZW DRYER- ELE
Admiral CYE4000AGW DRYER- ELE
Magic Chef CYE4000AYA DRYER- ELE
Magic Chef CYE4000AYS DRYER- ELE
Magic Chef CYE4000AYW DRYER- ELE
Magic Chef CYE4000AZS DRYER- ELE
Magic Chef CYE4000AZW DRYER- ELE
Admiral CYG1000AWW DRYER- GAS
Magic Chef CYG1005AWW DRYER- GAS
Magic Chef CYG2000AWA DRYER- GAS
Magic Chef CYG2000AWW DRYER- GAS
Magic Chef CYG3004AWW DRYER- GAS
Magic Chef CYG3005AWW DRYER- GAS
Magic Chef CYG4000AWA DRYER- GAS
Magic Chef CYG4000AWS DRYER- GAS
Magic Chef CYG4000AWW DRYER- GAS
Hardwick D-150 RANGE- F/S STD ELE
Hardwick D-170 RANGE- F/S STD ELE
Hardwick D-445 SURFACE UNIT- ELE
Hardwick D-456 SURFACE UNIT- ELE
Hardwick D-950 RANGE- F/S STD ELE
Amana D1150.000 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air D120 RANGE- D/I STD DDRAFT ELE
Amana D1200 MWAVE - FAMILY SIZE (60 HZ)
Amana D1250 MWAVE - FAMILY SIZE (60 HZ)
Amana D1270.000 MWAVE - FAMILY SIZE (60 HZ)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Wall Oven F2 error code repair paulnucc Oven Repair (including Ranges and Cooktops) 0 07-20-2014 09:21 AM
maytag wall oven error code F5 net2net69 Oven Repair (including Ranges and Cooktops) 1 05-03-2012 06:02 PM
GE Wall Oven - Error Code sgodwin14 Oven Repair (including Ranges and Cooktops) 0 08-22-2010 09:41 AM
GE Wall Oven F7 Error Code Philster Oven Repair (including Ranges and Cooktops) 0 02-27-2010 07:41 AM
Maytag Wall Oven Error Code AmandaWest Washer Repair 1 11-17-2009 03:30 PM
