Discuss
Kitchen Aid Stove Top Element replacement - trouble
 in
Hi. Kecc500xbo I'm trying to save a bunch of work already put into what should have been a simple job.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchen Aid Stove Top Element replacement - trouble
  #1 (permalink)
Old 01-22-2017, 11:25 AM
Junior Member
Mark Duess is on a distinguished road
Default Kitchen Aid Stove Top Element replacement - trouble
Model Number: Kecc500xbo   Brand: Kitchen Aid   Age: More than 10 years
Hi.
Kecc500xbo
The large front element (Front Left) wasn't working. I called Kitchen Aid and they was able to provide me with a part number. I ordered the part and when it arrived I have found that it doesn't look exactly the same. I've spoken with the supplier and Kitchen aid several times and I'm told this is a suitable part but they cannot tell me how it should be connected. So I'm reaching out to you for some help.
I'm going to add pictures if I can.
First problem is the size doesn't match. If I can actually get the wires figured out, will it be ok to place the element without having it sit in the same spot , reattaching the old legs may not work as the base is larger on the new one? potentially sitting on the metal base?
Second problem is that the connectors are different.
picture 1, shows the old element , note the black wire running back to itself and the red wire attaching on the side.
picture 2 new element, note a black wire running back to itself on other side, and a metal connection as well
picture 3, old element closeup showing the markings.
picture 4, new element close-up showing markings
picture 5 , new element with two connections made..
So basically I have two of the four wires transferred easily. What's left is the black and red.
On the old one the black is labelled 1a and it doesn't seem to have a matching home, as the terminal marked 1a the new one has the metal connector back to the burner. In picture four you'll see there is a terminal on the end of the short black wire on the new one, which may actually be connected to 1a.. I have no idea, Any advise is greatly appreciated.
Related Models
Whirlpool KECC501BAL0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC501BAL1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC501BAL2 ELECTRIC COOKTOP
Whirlpool KECC501BBL0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC501BBL1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC501BBL2 ELECTRIC COOKTOP
Whirlpool KECC501BWH0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC501BWH1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC501BWH2 ELECTRIC COOKTOP
Whirlpool KECC501GAL0 ELECTRIC COOKTOP
Whirlpool KECC501GAL1 ELECTRIC COOKTOP
Whirlpool KECC501GAL2 ELECTRIC COOKTOP
Whirlpool KECC501GBL0 ELECTRIC COOKTOP
Whirlpool KECC501GBL1 ELECTRIC COOKTOP
Whirlpool KECC501GBL2 ELECTRIC COOKTOP
Whirlpool KECC501GBL3 ELECTRIC COOKTOP
Whirlpool KECC501GBT3 ELECTRIC COOKTOP
Whirlpool KECC501GWH0 ELECTRIC COOKTOP
Whirlpool KECC501GWH1 ELECTRIC COOKTOP
Whirlpool KECC501GWH2 ELECTRIC COOKTOP
Whirlpool KECC501GWH3 ELECTRIC COOKTOP
Whirlpool KECC502BAL0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502BAL1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502BAL2 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502BBL0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502BBL1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502BBL2 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502BWH0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502BWH1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502BWH2 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GAL0 ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GAL1 COOKTOP
Whirlpool KECC502GAL2 COOKTOP
Whirlpool KECC502GBL0 ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GBL05 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GBL06 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GBL1 COOKTOP
Whirlpool KECC502GBL2 COOKTOP
Whirlpool KECC502GBL3 COOKTOP
Whirlpool KECC502GBL4 COUNTER UNIT ELECTRIC
Whirlpool KECC502GBT0 ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GBT1 COOKTOP
Whirlpool KECC502GBT2 COOKTOP
Whirlpool KECC502GBT3 COOKTOP
Whirlpool KECC502GBT4 COUNTER UNIT ELECTRIC
Whirlpool KECC502GWH0 ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GWH05 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GWH06 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC502GWH1 COOKTOP
Whirlpool KECC502GWH2 COOKTOP
Whirlpool KECC502GWH3 COOKTOP
Whirlpool KECC502GWH4 COUNTER UNIT ELECTRIC
Whirlpool KECC505KSS02 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC506RBL00 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RBL01 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RBL02 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RBL03 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RBL04 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RBL05 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RSS00 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RSS01 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RSS02 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RSS03 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RSS04 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RSS05 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RWH00 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RWH01 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RWH02 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC506RWH03 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC507BAL0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507BAL1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507BAL2 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507BBL0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507BBL1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507BBL2 30" ELECTRIC BUILT-IN COOKTOP
KitchenAid KECC507BBS2 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507BWH0 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507BWH1 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507BWH2 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507GAL0 30" ELECTRIC BUILD-IN-COOKTOP
Whirlpool KECC507GAL1 COOKTOP
Whirlpool KECC507GAL2 COOKTOP
Whirlpool KECC507GAL3 COOKTOP
Whirlpool KECC507GBL0 30" ELECTRIC BUILD-IN-COOKTOP
Whirlpool KECC507GBL1 COOKTOP
Whirlpool KECC507GBL2 COOKTOP
Whirlpool KECC507GBL3 COOKTOP
Whirlpool KECC507GBT0 30" ELECTRIC BUILD-IN-COOKTOP
Whirlpool KECC507GBT1 COOKTOP
Whirlpool KECC507GBT2 COOKTOP
Whirlpool KECC507GBT3 COOKTOP
Whirlpool KECC507GWH0 30" ELECTRIC BUILD-IN-COOKTOP
Whirlpool KECC507GWH1 COOKTOP
Whirlpool KECC507GWH2 COOKTOP
Whirlpool KECC507GWH3 COOKTOP
Whirlpool KECC507GWW2 ELECTRIC COUNTER UNIT
Whirlpool KECC507GWW3 COOKTOP
Whirlpool KECC507HSS0 ELECTRIC COUNTER UNIT (COOKTOP)
Whirlpool KECC507HSS1 ELECTRIC COUNTER UNIT
Whirlpool KECC507HSS2 ELECTRIC COUNTER UNIT
Whirlpool KECC507KBL0 COUNTER UNIT ELECTRIC
Whirlpool KECC507KBL02 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507KBL03 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507KBL1 COUNTER UNIT ELECTRIC
Whirlpool KECC507KBT0 COUNTER UNIT ELECTRIC
Whirlpool KECC507KBT02 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507KBT03 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507KBT1 COUNTER UNIT ELECTRIC
Whirlpool KECC507KSS0 COUNTER UNIT ELECTRIC
Whirlpool KECC507KSS02 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507KSS03 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507KSS1 COUNTER UNIT ELECTRIC
Whirlpool KECC507KWH0 COUNTER UNIT ELECTRIC
Whirlpool KECC507KWW0 COUNTER UNIT ELECTRIC
Whirlpool KECC507KWW02 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507KWW03 36" ELECTRIC BUILT-IN COOKTOP
Whirlpool KECC507KWW1 COUNTER UNIT ELECTRIC
Whirlpool KECC507RBB00 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC507RBB01 30" ELECTRIC CERAN COOKTOP
Whirlpool KECC507RBB02 30" ELECTRIC CERAN COOKTOP
  #2 (permalink)
Old 02-01-2017, 11:57 AM
Junior Member
Default new information
Adding a wiring diagram.
  #3 (permalink)
Old 02-13-2017, 09:01 AM
Junior Member
Default update - resolved
Lots of views but not one piece of advice? anyway..This is to advise anyone who might be reading this thread that the resolution was found in the sense I was able to identify that Whirlpool did give me the wrong part number and I ended up purchasing the wrong part. Don't trust whirlpool, especially if they can't identify the model number. I found the right part with help from another forum..appliance411.... and I subsequently purchased the proper substitute from a seller on ********.
The new element was the wrong size and from continuity tests I don't think it would have been usable.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacement Element for old Westinghouse Stove mapit4 Oven Repair (including Ranges and Cooktops) 2 10-02-2016 08:56 PM
Glasstop replacement for electric Kitchen Aid stove Ken Do Oven Repair (including Ranges and Cooktops) 0 01-17-2016 09:00 PM
stove top element replacement cwoodcock Oven Repair (including Ranges and Cooktops) 0 12-30-2011 08:53 AM
Trouble with Kitchen Aid Dishwasher cameroninoc Dishwasher Repair 13 01-14-2009 09:51 PM
stove element replacement docke Oven Repair (including Ranges and Cooktops) 1 05-30-2008 07:40 PM
