mikehende
#1 Posted : Thursday, January 12, 2017 7:14:47 AM(UTC)
mikehende
Hey guys, I bought the propane stove in the pic off ******** early last year, I cannot find the manufacturer of this stove anywhere on the net as the only description on the stove is "Flaming Griller BUR6800" as is showing in the pic.
http://i493.photobucket....de/grill_zpsol44zj6x.jpg
It's a great stove with really high flame but now not getting the left burner to light and nowhere as high a flame as normal on the right side burner.
We had a similar issue at Fall time last year and had disconnected the hose to the stove and used a compressor to blow out the burners and that did the trick but now this problem again. Since he hadn't used the stove all that much since then I am not sure if this is the same issue and will attempt to blow it out again when I get back the compressor.
I am being told only other thing would be the regulator needs replacing but since the right side burner was lighting when the left wasn't I am thinking that should mean that the fault should not be regulator related? Any ideas/advice please?
