Discuss
Thermador Grill Erratic
 in
Hi, I have a 17-year old Thermador Professional Rangetop, model number GCT48 4GG, that I have owned since it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Grill Erratic
  #1 (permalink)
Old 11-02-2009, 04:29 PM
ruscar ruscar is offline
Junior Member
ruscar is on a distinguished road
Default Thermador Grill Erratic
Model Number: GCT48 4GG   Brand: Thermador   Age: More than 10 years
I have a 17-year old Thermador Professional Rangetop, model number GCT48 4GG, that I have owned since it was new, on which the grill is now functioning erratically. When I first turn on the grill (to the highest setting) the glow plug heats up and about 30 seconds later the gas valve opens and the burner lights fully—all as it should be—but after about 5 seconds the gas shuts off then turns back on again after 10 seconds or so but only at about half flow rate this time. This on-off cycle continues for 10-15 minutes before the gas finally stays on continuously, but only at a reduced flow rate, so the grill never gets fully hot, only medium at most no matter what setting I set on the dial.
I have taken the grill apart, thoroughly cleaned and inspected it, and everything looks to be in good condition, but it stills functions as described. The glow plug seems to be getting fully hot, both the inner and outer parts of the tip. I suspect that the grill safety valve might be malfunctioning, but would like to hear from the experts their opinions.
Thanks.
Related Models
Thermador GCT484GG
Thermador GCT486G
General Electric GCU21LGTAFBB Refrigerator
General Electric GCU21LGTAFSS Refrigerator
General Electric GCU21YESAFBB Refrigerator
General Electric GCU21YESAFSS Refrigerator
General Electric GCU21YETBFSS Refrigerator
General Electric GCU23MITAFBB Refrigerator
Thermador GCV36
Thermador GCV36G
Whirlpool GD22DCXHB00
Whirlpool GD22DCXHB01
Whirlpool GD22DCXHB02
Whirlpool GD22DCXHS00
Whirlpool GD22DCXHS01
Whirlpool GD22DCXHS02
Whirlpool GD22DCXHT00
Whirlpool GD22DCXHT01
Whirlpool GD22DCXHT02
Whirlpool GD22DCXHW00
Whirlpool GD22DCXHW01
Whirlpool GD22DCXHW02
Whirlpool GD22DFXFB00
Whirlpool GD22DFXFB01
Whirlpool GD22DFXFB02
Whirlpool GD22DFXFB03
Whirlpool GD22DFXFB04
Whirlpool GD22DFXFN00
Whirlpool GD22DFXFN01
Whirlpool GD22DFXFN02
Whirlpool GD22DFXFN03
Whirlpool GD22DFXFN04
Whirlpool GD22DFXFT02
Whirlpool GD22DFXFT03
Whirlpool GD22DFXFT04
Whirlpool GD22DFXFW00
Whirlpool GD22DFXFW01
Whirlpool GD22DFXFW02
Whirlpool GD22DFXFW03
Whirlpool GD22DFXFW04
Whirlpool GD22DKXFW00
Whirlpool GD22DKXFW01
Whirlpool GD22DKXHW00
Whirlpool GD22DKXHW01
Whirlpool GD22DKXHW02
Whirlpool GD22DKXHW03
Whirlpool GD22DQXFB00
Whirlpool GD22DQXFN00
Whirlpool GD22DQXFW00
Whirlpool GD22SFXHS00
Whirlpool GD22SFXHS01
Whirlpool GD22SFXHS02
Whirlpool GD22SFXHS03
Whirlpool GD22SFXHS04
Whirlpool GD22SFXHS05
Whirlpool GD25BFCHB00
Whirlpool GD25BFCHB01
Whirlpool GD25BFCHT00
Whirlpool GD25BFCHT01
Whirlpool GD25BFCHW00
Whirlpool GD25BFCHW01
Whirlpool GD25DCXHS00
Whirlpool GD25DCXHS01
Whirlpool GD25DFXFB00
Whirlpool GD25DFXFB01
Whirlpool GD25DFXFB02
Whirlpool GD25DFXFB03
Whirlpool GD25DFXFN00
Whirlpool GD25DFXFN01
Whirlpool GD25DFXFN02
Whirlpool GD25DFXFN03
Whirlpool GD25DFXFT02
Whirlpool GD25DFXFT03
Whirlpool GD25DFXFW00
Whirlpool GD25DFXFW01
Whirlpool GD25DFXFW02
Whirlpool GD25DFXFW03
Whirlpool GD25DIXHB00
Whirlpool GD25DIXHB02
Whirlpool GD25DIXHS00
Whirlpool GD25DIXHS02
Whirlpool GD25DIXHT00
Whirlpool GD25DIXHT02
Whirlpool GD25DIXHW00
Whirlpool GD25DIXHW02
Whirlpool GD25DQXFB00
Whirlpool GD25DQXFB01
Whirlpool GD25DQXFN00
Whirlpool GD25DQXFN01
Whirlpool GD25DQXFW00
Whirlpool GD25DQXFW01
Whirlpool GD25FFCHB00 Refrigerator
Whirlpool GD25FFCHB01
Whirlpool GD25FFCHT00 Refrigerator
Whirlpool GD25FFCHT01
Whirlpool GD25FFCHW00 Refrigerator
Whirlpool GD25FFCHW01
Whirlpool GD25SFCHS10
Whirlpool GD25SFCHS11
Whirlpool GD25SFCHS111
Whirlpool GD25SFXHS00
Whirlpool GD25SFXHS01
Whirlpool GD25SFXHS02
Whirlpool GD25SFXHS03
Whirlpool GD25SFXHS04
Whirlpool GD25SFXHS05
Whirlpool GD25SHAXLB01
Whirlpool GD25SHAXLQ01
Whirlpool GD25SHAXLT01
Whirlpool GD25SSFCHS10
Whirlpool GD27DFXFB00
Whirlpool GD27DFXFB01
Whirlpool GD27DFXFB02
Whirlpool GD27DFXFB03
Whirlpool GD27DFXFN00
Whirlpool GD27DFXFN01
Whirlpool GD27DFXFN02
Whirlpool GD27DFXFN03
Whirlpool GD27DFXFT02
Whirlpool GD27DFXFT03
  #2 (permalink)
Old 11-02-2009, 06:52 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad gas safety valve. I would replace the igniter as well to make the repair more relaible.
- The gas safety valve Part number: AP2832925
- The igniter Part number: AP3674290
Here are the breakdown diagrams and Replacement parts for THERMADOR GCT484GG | AppliancePartsPros.com
__________________
  #3 (permalink)
Old 11-02-2009, 08:18 PM
Junior Member
Default Follow-up
Thanks Gene. I believe you, since you agree with me, ha!
The safety valve you show does not look exactly like the oem valve on the grill. The difference is that the inlet port (large coupling) is on the side of mine, which would be pointed directly at you in the picture of the replacement part you recommended, as opposed to coming out the top (to the right side of that picture).
Do you know where I can get the correctly configured valve? I have been unable to locate one so far, which means I would also have to replace the tubing between the regulator and the safety valve. The codes on the side of the original are on three lines, as follows:
8940
NC-4125-5
16003-V
Thanks again.
Russ
  #4 (permalink)
Old 11-03-2009, 03:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Russ,
The gas safety valve with the part number AP2832925 came up as a search result for the model number you posted. This is the OEM part recommended by the manufacturer.
__________________
  #5 (permalink)
Old 11-03-2009, 04:47 PM
Junior Member
Default
Thanks, Gene.
I agree—that's the part that shows up in all my searches for a replacement too, but it doesn't match the one that came with the grill originally. I have not been able to find one that matches it using any search criteria I can think of. I guess the best thing to do now is order tubing that will reach up and around to the inlet port on top of that replacement part, since I am very reluctant to try bending the existing tube to reach that location for fear of breaking it.
Thanks again for your help, Gene.
  #6 (permalink)
Old 11-04-2009, 12:29 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I double checked the diagram
and found there two burners, #30 and #31. They have different gas safety valves, #29 and #33. The gas safety valve with the reference number 29 has been discontinued and is no longer available.
If this is the part you needed, call the Appliance Parts Pros customer service and they might get one for you because the data base shows one available (if there is no errors).
The other valve is still available and the part number I posted earlier.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Range Grill Gas Valve Needed DonD Oven Repair (including Ranges and Cooktops) 5 08-31-2009 06:35 PM
Thermador Gas Grill s11845 Microwave Repair 1 03-09-2009 08:25 PM
Spins erratic diyme Washer Repair 4 01-13-2009 03:42 AM
Function ? Thermador cooktop w/grill Bob338 Oven Repair (including Ranges and Cooktops) 2 03-23-2008 05:18 PM
how to replace igniter on thermador gas grill cosomactoo Oven Repair (including Ranges and Cooktops) 1 09-19-2007 08:24 PM
