Discuss
Amana oven won't light
 in
Amana gas stove. Top burners light. Neither the boiler or oven igniter light. I did put in a new oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana oven won't light
  #1 (permalink)
Old 01-10-2017, 04:55 PM
Junior Member
rope13 is on a distinguished road
Default Amana oven won't light
Model Number: ARGS7650E   Brand: Amana   Age: More than 10 years
Amana gas stove. Top burners light. Neither the boiler or oven igniter light. I did put in a new oven igniter and still nothing. Any thoughts?
Related Models
Amana ARGS7650E RANGE- S/C S/I GAS
Amana ARGS7650LL RANGE- S/C S/I GAS
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Amana ARHC8700WW RANGE- S/C F/S ELE
Amana ARHSC8750E RANGE- S/C S/I DDRAFT ELE
Amana ARHSC8750WW RANGE- S/C S/I DDRAFT ELE
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L RANGE- S/C S/I DDRAFT GAS
Amana ARO3100W RANGE- S/C S/I DDRAFT GAS
Amana ARO3400L RANGE- S/C S/I DDRAFT GAS
Amana ARO3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR-201 RANGE- S/C S/I DDRAFT ELE
Amana ARR-201 RANGE- S/C S/I DDRAFT GAS
Amana ARR-401 RANGE- S/C S/I DDRAFT ELE
Amana ARR-401 RANGE- S/C S/I DDRAFT GAS
Amana ARR-402 RANGE- S/C S/I DDRAFT ELE
Amana ARR-402 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT ELE
Amana ARR-412 RANGE- S/C S/I DDRAFT ELE
Amana ARR-415 RANGE- S/C S/I DDRAFT ELE
Amana ARR101W RANGE- S/C S/I DDRAFT ELE
Amana ARR301 RANGE- S/C S/I DDRAFT ELE
Amana ARR301W RANGE- S/C S/I DDRAFT ELE
Amana ARR303 RANGE- S/C S/I DDRAFT ELE
Amana ARR303W RANGE- S/C S/I DDRAFT ELE
Amana ARR305 RANGE- S/C S/I DDRAFT ELE
Amana ARR3100L RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NL RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NW RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 01-10-2017, 05:08 PM
Junior Member
I replaced the lower element and still the boiler element won't light nor the new lower one.
  #3 (permalink)
Old 01-10-2017, 05:13 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Your model number is OK, but to look up your range I need a M.F.G. number something like this....... MFG P1130752NE.
Do your igniters glow at all?
Do you have 120 volts AC to the igniter?
I wonder if there is a thermal fuse?
  #4 (permalink)
Old 01-10-2017, 05:26 PM
Junior Member
Default
The igniters don't glow at all. P1130755NE I did put in a new lower igniter.
  #5 (permalink)
Old 01-11-2017, 10:08 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
The electronic control board and the gas valve are no longer available for this range.
I have no way of knowing what is wrong with your range without doing some testing with a volt/ohm meter.
If I were there I would be tracing the wiring back from the igniters to the gas valve to the EC board.
I suspect that since both igniters are out, it has to do with the electronic control board. Maybe it has a burnt wire to it or maybe a burnt trace or maybe its just quit.
I wish I had a wiring diagram. Then I could tell you if there is a thermal fuse or safety device inline with the power to the igniters.
Whirlpool 31944801 Erciii, Gas-No Longer Available - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air Gas Oven Model #JGW8130ADB Oven Ignitor won't light broiler does light delvarela Oven Repair (including Ranges and Cooktops) 1 11-13-2015 03:53 PM
Amana Stove won't light. dusouski Oven Repair (including Ranges and Cooktops) 0 08-16-2011 07:02 PM
Blinking Blue Lights (Oven ON Light & Oven Heating Light bubbah2os Oven Repair (including Ranges and Cooktops) 1 02-05-2010 01:07 PM
Amana Oven Light Assembly Socket Screw pete3027 Oven Repair (including Ranges and Cooktops) 1 12-18-2008 09:42 AM
