Discuss
Frigidaire double oven with no power
 in
Hi, I have a Frigidaire double wall oven FEB30T7FCC that isn't working. We had used the self cleaning function and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire double oven with no power
  #1 (permalink)
Old 01-09-2017, 03:39 PM
Junior Member
thubbard is on a distinguished road
Default Frigidaire double oven with no power
Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire double wall oven FEB30T7FCC that isn't working. We had used the self cleaning function and it operated for several hours before the control panel went blank. I had this happen about a year before and reset the thermal switch in the back of the oven. My wife used the self cleaning function again and the same issue occurred. Unlike the first time, when I reset the thermal switches it didn't restore power to the unit.
My question is whether this is a control panel issue, or could it be anything else. The circuit breaker was turned off and on, as well as the thermal switch, and there still is no indication of any power to the unit. Would you suggest replacing the control unit? I assume the power initially comes to the unit and if there isn't any navigability using the panel, then it must be damaged. Is that a reasonable guess?
Thanks in advance for your suggestions. It's appreciated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double Oven Power Cycling seschaffer Oven Repair (including Ranges and Cooktops) 0 07-25-2016 08:32 AM
Whirlpool Double Oven. No Power, No Beeps pssmetana Refrigerator & Freezer Repair 2 01-22-2015 08:11 PM
double oven appears to have no power KEVIN64 Oven Repair (including Ranges and Cooktops) 1 09-06-2012 04:37 AM
Lost power Jenn Air dual feul double oven - power won't return my jenn air Oven Repair (including Ranges and Cooktops) 1 11-08-2011 06:46 AM
Thermador Double Oven - No Power slkc Oven Repair (including Ranges and Cooktops) 0 06-05-2008 08:56 AM
