Oven no longer works, stove top is fine though
Our oven stopped working awhile back. The stove top elements work fine, they heat up etc etc. The oven elements
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven no longer works, stove top is fine though
  #1 (permalink)
Old 01-04-2017, 09:38 AM
Junior Member
wonderwyrm is on a distinguished road
Default Oven no longer works, stove top is fine though
Model Number: FEF336FMF   Brand: Frigidaire   Age: 5 - 10 years
The oven elements though do not work, broil nor bake. The control panel seems to work,the bulb is fine as well, the display indicates temperature, broil setting, timer, etc.
When we setup the oven to preheat, we can hear the clicking like its turning on but nothing happens. I inspected the elements visually and they seem to look fine. I was told it could be the elements that need to be replaced, however I did more research and read that if the stove top elements are working fine that the control board may need to be replaced instead.
My next step is to purchase a multimeter and test the elements. Assuming they are fine, what are my next steps or could it be the control board that needs to be replaced?
Related Models
Frigidaire FEF336WHSA Frg(v1) / Electric Range
Frigidaire FEF336WHSB Frg(v2) / Electric Range
Frigidaire FEF336WHSC Frigidaire/electric Range
Frigidaire FEF336WHSD Frigidaire/electric Range
Frigidaire FEF337BADA Frg(v2) / Electric Range
Frigidaire FEF337BADB Frg(v1) / Electric Range
Frigidaire FEF337BAWA Frg(v1) / Electric Range
Frigidaire FEF337BAWB Frg(v2) / Electric Range
Frigidaire FEF339ESA Frigidaire/range
Frigidaire FEF339ESB Frigidaire/range
Frigidaire FEF339ESC Frigidaire/range
Frigidaire FEF339FSA Frigidaire/range
Frigidaire FEF339FSB Frigidaire/electric Range
Frigidaire FEF339FSC Frigidaire/range
Frigidaire FEF342BADA Frg(v2) / Electric Range
Frigidaire FEF342BADB Frg(v3) / Electric Range
Frigidaire FEF342BAWA Frg(v1) / Electric Range
Frigidaire FEF342BAWB Frg(v2) / Electric Range
Frigidaire FEF350BADA Frg(v2) / Electric Range
Frigidaire FEF350BADB Frg(v2) / Electric Range
Frigidaire FEF350BADC Frg(v1) / Electric Range
Frigidaire FEF350BADD Frg(v2) / Electric Range
Frigidaire FEF350BADE Frg(v3) / Electric Range
Frigidaire FEF350BADF Frg(v1) / Electric Range
Frigidaire FEF350BADG Frg(v1) / Electric Range
Frigidaire FEF350BADH Frg(v1) / Electric Range
Frigidaire FEF350BAWA Frg(v1) / Electric Range
Frigidaire FEF350BAWB Frg(v1) / Electric Range
Frigidaire FEF350BAWC Frg(v3) / Electric Range
Frigidaire FEF350BAWD Frg(v4) / Electric Range
Frigidaire FEF350BAWE Frg(v4) / Electric Range
Frigidaire FEF350BAWF Frg(v2) / Electric Range
Frigidaire FEF350BAWG Frg(v2) / Electric Range
Frigidaire FEF350BAWH Frg(v2) / Electric Range
Frigidaire FEF350BEDA Frg(v1) / Electric Range
Frigidaire FEF350BEDB Frg(v1) / Electric Range
Frigidaire FEF350BEWA Frg(v2) / Electric Range
Frigidaire FEF350BEWB Frg(v2) / Electric Range
Frigidaire FEF350CADA Frg(v2) / Electric Range
Frigidaire FEF350CADB Frg(v1) / Electric Range
Frigidaire FEF350CASA Frg(v1) / Electric Range
Frigidaire FEF350CASB Frg(v2) / Electric Range
Frigidaire FEF350CASC Frg(v5) / Electric Range
Frigidaire FEF350CASD Frg(v6) / Electric Range
Frigidaire FEF350CASE Frg(v5) / Electric Range
Frigidaire FEF350CASF Frg(v3) / Electric Range
Frigidaire FEF350CASG Frg(v3) / Electric Range
Frigidaire FEF350CASH Frg(v3) / Electric Range
Frigidaire FEF350CAWA Frg(v1) / Electric Range
Frigidaire FEF350CAWB Frg(v3) / Electric Range
Frigidaire FEF350CCTA Frg(v1) / Electric Range
Frigidaire FEF350CCTB Frg(v2) / Electric Range
Frigidaire FEF350CCTC Frg(v0) / Electric Range
Frigidaire FEF350CCTD Frg(v0) / Electric Range
Frigidaire FEF350CCTE Frg(v0) / Electric Range
Frigidaire FEF350CCTF Frg(v0) / Electric Range
Frigidaire FEF350CESA Frg(v3) / Electric Range
Frigidaire FEF350CESB Frg(v3) / Electric Range
Frigidaire FEF350CETA Frg(v4) / Electric Range
Frigidaire FEF350CETB Frg(v4) / Electric Range
Frigidaire FEF350SADA Frg(v2) / Electric Range
Frigidaire FEF350SADB Frg(v1) / Electric Range
Frigidaire FEF350SADC Frg(v1) / Electric Range
Frigidaire FEF350SADD Frg(v1) / Electric Range
Frigidaire FEF350SADE Frg(v1) / Electric Range
Frigidaire FEF350SADF Frg(v4) / Electric Range
Frigidaire FEF350SADG Frg(v4) / Electric Range
Frigidaire FEF350SADH Frg(v4) / Electric Range
Frigidaire FEF350SADJ Frg(v1) / Electric Range
Frigidaire FEF350SAWA Frg(v1) / Electric Range
Frigidaire FEF350SAWB Frg(v2) / Electric Range
Frigidaire FEF350SAWC Frg(v2) / Electric Range
Frigidaire FEF350SAWD Frg(v2) / Electric Range
Frigidaire FEF350SAWE Frg(v2) / Electric Range
Frigidaire FEF350SAWF Frg(v5) / Electric Range
Frigidaire FEF350SAWG Frg(v5) / Electric Range
Frigidaire FEF350SAWH Frg(v5) / Electric Range
Frigidaire FEF350SAWJ Frg(v2) / Electric Range
Frigidaire FEF350XAWA Frg(v1) / Electric Range
Frigidaire FEF351CSA Frigidaire/electric Range
Frigidaire FEF351CSB Frigidaire/electric Range
Frigidaire FEF351CSC Frigidaire/electric Range
Frigidaire FEF351CUA Frigidaire/electric Range
Frigidaire FEF351CUB Frigidaire/electric Range
Frigidaire FEF351CUC Frigidaire/electric Range
Frigidaire FEF351CWA Frigidaire/electric Range
Frigidaire FEF351CWB Frigidaire/electric Range
Frigidaire FEF351CWC Frigidaire/electric Range
Frigidaire FEF351SADA Frg(v2) / Electric Range
Frigidaire FEF351SADB Frg(v1) / Electric Range
Frigidaire FEF351SAWA Frg(v1) / Electric Range
Frigidaire FEF351SAWB Frg(v2) / Electric Range
Frigidaire FEF351SGWA Frg(v0) / Electric Range
Frigidaire FEF351SGWB Frg(v1) / Electric Range
Frigidaire FEF351SGWC Frg(v2) / Electric Range
Frigidaire FEF352ASA Frigidaire/electric Range
Frigidaire FEF352ASB Frigidaire/electric Range
Frigidaire FEF352ASC Frigidaire/electric Range
Frigidaire FEF352ASD Frigidaire/electric Range
Frigidaire FEF352ASE Frigidaire/electric Range
Frigidaire FEF352ASF Frigidaire/electric Range
Frigidaire FEF352ASG Frigidaire/electric Range
Frigidaire FEF352ASH Frigidaire/electric Range
Frigidaire FEF352AUA Frigidaire/range
Frigidaire FEF352AUC Frigidaire/electric Range
Frigidaire FEF352AUD Frigidaire/electric Range
Frigidaire FEF352AUE Frigidaire/electric Range
Frigidaire FEF352AUF Frigidaire/electric Range
Frigidaire FEF352AUG Frigidaire/electric Range
Frigidaire FEF352AUH Frigidaire/electric Range
Frigidaire FEF352AWA Frigidaire/range
Frigidaire FEF352AWC Frigidaire/electric Range
Frigidaire FEF352AWD Frigidaire/electric Range
Frigidaire FEF352AWE Frigidaire/electric Range
Frigidaire FEF352AWF Frigidaire/electric Range
  #2 (permalink)
Old 01-04-2017, 03:12 PM
ThatGuy's Avatar
APP Volunteer
ThatGuy is on a distinguished road
I'd check the wires to the elements and all the way back to the control board. If all of the wires are OK, then its probably your control board.
Frigidaire 316455400 Oven Control Board - AppliancePartsPros.com
You might want this part too. Its up to you. They can be hard to remove.
Frigidaire 316220701 Control Overlay - AppliancePartsPros.com
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool oven does not light, stove works fine pop702 Oven Repair (including Ranges and Cooktops) 9 01-31-2013 01:36 PM
Oven won't heat, Stove works fine Richard P Oven Repair (including Ranges and Cooktops) 1 06-08-2012 01:06 PM
Oven that will not get hot and doesn't seem to light, but stove top works just fine broganspainting Oven Repair (including Ranges and Cooktops) 0 01-24-2011 07:11 PM
Oven will not heat up / stove works fine Erikation Oven Repair (including Ranges and Cooktops) 0 10-04-2010 09:07 PM
Whirlpool Oven won't heat stove works fine tnearman Oven Repair (including Ranges and Cooktops) 2 10-18-2007 09:13 AM
