Discuss
Spark Ignitor Switch
 in
I have one burner on my Magic Chef range (model 31MA-3KX, serial # 05C225407667) which intermittently will not spark (most
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Spark Ignitor Switch
  #1 (permalink)
Old 01-04-2017, 03:48 AM
Junior Member
Sodbuster is on a distinguished road
Default Spark Ignitor Switch
Model Number: 31MA-3KX   Brand: Magic Chef   Age: More than 10 years
I have one burner on my Magic Chef range (model 31MA-3KX, serial # 05C225407667) which intermittently will not spark (most of the time), the other burners are fine. I believe the switch for that burner is bad and want to replace it. How do I disassemble to gain access to the part? My manual states that the top does not remove because there are sealed burners. I would appreciate any suggestions.
Related Models
Magic Chef 31MA-3KX RANGE- F/S STD GAS
Magic Chef 31MA-3KX-OC RANGE- F/S STD GAS
Magic Chef 31MA-3KX-ON RANGE- F/S STD GAS
Magic Chef 31MA-5KLX RANGE-F/S CONT CLEAN GAS
Magic Chef 31MA-5KV RANGE- F/S STD GAS
Magic Chef 31MA-5KX RANGE- F/S STD GAS
Magic Chef 31MN-23KX-ON RANGE- F/S STD GAS
Magic Chef 31MN-3KX RANGE- F/S STD GAS
Magic Chef 31MN-3KX-OC RANGE- F/S STD GAS
Magic Chef 31MN-3KX-ON RANGE- F/S STD GAS
Magic Chef 31MN-5KLX RANGE-F/S CONT CLEAN GAS
Magic Chef 31MN-5KV RANGE- F/S STD GAS
Magic Chef 31MN-5KX RANGE- F/S STD GAS
Hoover 32
Frigidaire 32-0007-00-02 Tap(v1) / Gas Range
Frigidaire 32-0007-00-03 Tap(v3) / Gas Range
Frigidaire 32-0007-00-05 Tap(v1) / Gas Range
Frigidaire 32-0007-23-02 Tap(v2) / Gas Range
Frigidaire 32-0007-23-03 Tap(v4) / Gas Range
Frigidaire 32-0007-23-05 Tap(v2) / Gas Range
Frigidaire 32-0027-00-02 Tap(v1)
Frigidaire 32-0027-00-03 Tap(v3)
Frigidaire 32-0027-00-04 Tap(v5)
Frigidaire 32-0027-23-02 Tap(v2)
Frigidaire 32-0027-23-03 Tap(v4)
Frigidaire 32-0027-23-04 Tap(v6)
Frigidaire 32-0117-00-02 Tap(v1) / Gas Range
Frigidaire 32-0117-00-03 Tap(v3) / Gas Range
Frigidaire 32-0117-23-02 Tap(v2) / Gas Range
Frigidaire 32-0117-23-03 Tap(v4) / Gas Range
Frigidaire 32-0127 ELECTRIC RANGE
Frigidaire 32-0127-00-02 Tap(v1) / Gas Range
Frigidaire 32-0127-00-03 Tap(v3) / Gas Range
Frigidaire 32-0127-23-02 Tap(v2) / Gas Range
Frigidaire 32-1002-00-01 (v1)
Frigidaire 32-1002-00-02 (v2)
Frigidaire 32-1002-00-03 (v3)
Frigidaire 32-1002-00-04 (v4)
Frigidaire 32-1002-00-05 (v5)
Frigidaire 32-1002-00-06 (v6)
Frigidaire 32-1002-00-07 (v7)
Frigidaire 32-1002-00-08 (v8)
Frigidaire 32-1002-00-09 (v9)
Frigidaire 32-1002-00-10 (v10)
Frigidaire 32-1002-00-11 (v11)
Frigidaire 32-1002-00-12 (v12)
Frigidaire 32-1002-23-01 (v13)
Frigidaire 32-1002-23-02 (v14)
Frigidaire 32-1002-23-03 (v15)
Frigidaire 32-1002-23-04 (v16)
Frigidaire 32-1002-23-05 (v17)
Frigidaire 32-1002-23-06 (v18)
Frigidaire 32-1002-23-07 (v19)
Frigidaire 32-1002-23-08 (v20)
Frigidaire 32-1002-23-09 (v21)
Frigidaire 32-1002-23-10 (v22)
Frigidaire 32-1002-23-11 (v23)
Frigidaire 32-1002-23-12 (v24)
Frigidaire 32-1002-32-01 (v13)
Frigidaire 32-1002-32-02 (v14)
Frigidaire 32-1002-32-03 (v15)
Frigidaire 32-1002-32-04 (v16)
Frigidaire 32-1002-32-05 (v17)
Frigidaire 32-1002-32-06 (v18)
Frigidaire 32-1002-32-07 (v19)
Frigidaire 32-1002-32-08 (v20)
Frigidaire 32-1002-32-09 (v21)
Frigidaire 32-1002-32-10 (v22)
Frigidaire 32-1002-32-11 (v23)
Frigidaire 32-1002-32-12 (v24)
Frigidaire 32-1002-45-01 (v1)
Frigidaire 32-1002-45-02 (v2)
Frigidaire 32-1002-45-03 (v3)
Frigidaire 32-1002-45-04 (v4)
Frigidaire 32-1002-45-05 (v5)
Frigidaire 32-1002-45-06 (v6)
Frigidaire 32-1002-45-07 (v7)
Frigidaire 32-1002-45-08 (v8)
Frigidaire 32-1002-45-09 (v9)
Frigidaire 32-1002-45-10 (v10)
Frigidaire 32-1002-45-11 (v11)
Frigidaire 32-1002-45-12 (v12)
Frigidaire 32-1002-57-01 (v13)
Frigidaire 32-1002-57-02 (v14)
Frigidaire 32-1002-57-03 (v15)
Frigidaire 32-1002-57-04 (v16)
Frigidaire 32-1002-57-05 (v17)
Frigidaire 32-1002-57-06 (v18)
Frigidaire 32-1002-57-07 (v19)
Frigidaire 32-1002-57-08 (v20)
Frigidaire 32-1002-57-09 (v21)
Frigidaire 32-1002-57-10 (v22)
Frigidaire 32-1002-57-11 (v23)
Frigidaire 32-1002-57-12 (v24)
Frigidaire 32-1002-66-01 (v1)
Frigidaire 32-1002-66-02 (v2)
Frigidaire 32-1002-66-03 (v3)
Frigidaire 32-1002-66-04 (v4)
Frigidaire 32-1002-66-05 (v5)
Frigidaire 32-1002-66-06 (v6)
Frigidaire 32-1002-66-07 (v7)
Frigidaire 32-1002-66-08 (v8)
Frigidaire 32-1002-66-09 (v9)
Frigidaire 32-1002-66-10 (v10)
Frigidaire 32-1002-66-11 (v11)
Frigidaire 32-1002-66-12 (v12)
Frigidaire 32-1004-00-01 Tap(v1) / Gas Range
Frigidaire 32-1004-23-01 Tap(v2) / Gas Range
Frigidaire 32-1007-00-01 Tap(v1) / Gas Range
Frigidaire 32-1007-00-02 Tap(v3) / Gas Range
Frigidaire 32-1007-00-03 Tap(v5) / Gas Range
Frigidaire 32-1007-00-04 Tap(v4) / Gas Range
Frigidaire 32-1007-23-01 Tap(v2) / Gas Range
Frigidaire 32-1007-23-02 Tap(v4) / Gas Range
Frigidaire 32-1007-23-03 Tap(v6) / Gas Range
Frigidaire 32-1007-23-04 Tap(v8) / Gas Range
Frigidaire 32-1008-00-01 Tap(v1) / Gas Range
Frigidaire 32-1008-00-02 Tap(v3) / Gas Range
Frigidaire 32-1008-23-01 Tap(v2) / Gas Range
Frigidaire 32-1008-23-02 Tap(v4) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
new spark ignitor wiring ajsmckay Oven Repair (including Ranges and Cooktops) 0 09-26-2013 05:46 PM
Spark Module or Spark Ignition Switch? Thriolith Oven Repair (including Ranges and Cooktops) 0 04-20-2012 10:02 PM
spark switch, switches and spark electrode crazyman Oven Repair (including Ranges and Cooktops) 1 03-29-2011 07:24 AM
No spark at burner - is it spark module or switch? Schoeman Oven Repair (including Ranges and Cooktops) 0 05-28-2010 01:18 PM
Ignitor won't spark MarkSprat Oven Repair (including Ranges and Cooktops) 0 11-24-2009 05:35 AM
