Discuss
Kenmore stove burners
 in
In July there was a pop sound while I was using the stove - husband & son checked it out
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore stove burners
  #1 (permalink)
Old 12-28-2016, 08:11 AM
Junior Member
Janet W is on a distinguished road
Exclamation Kenmore stove burners
Model Number: 79096223409   Brand: Kenmore   Age: 5 - 10 years
In July there was a pop sound while I was using the stove - husband & son checked it out - said it would be 300$ ish to replace the electrical panel thing, which I did not do. I cook almost every night and have used it continuously since then
Front left burner is pretty much on high when you use it, won't adjust to lower heat. Other 3 burners maybe don't get quite as hot as they used to, but they all work & I've had no problems cooking with it. This has been consistent since whatever happened in July and I do cook almost every night, I use all the burners.
Related Models
Kenmore 79096223409 ELECTRIC RANGE
Kenmore 7909622340A ELECTRIC RANGE
Kenmore 7909622340B ELECTRIC RANGE
Kenmore 7909622340C ELECTRIC RANGE
Kenmore 79096224400 ELECTRIC RANGE
Kenmore 79096224401 ELECTRIC RANGE
Kenmore 79096224403 ELECTRIC RANGE
Kenmore 79096224404 ELECTRIC RANGE
Kenmore 79096224406 ELECTRIC RANGE
Kenmore 79096224407 ELECTRIC RANGE
Kenmore 79096224408 ELECTRIC RANGE
Kenmore 79096224409 ELECTRIC RANGE
Kenmore 7909622440A ELECTRIC RANGE
Kenmore 7909622440B ELECTRIC RANGE
Kenmore 79096229400 ELECTRIC RANGE
Kenmore 79096229401 ELECTRIC RANGE
Kenmore 79096229403 ELECTRIC RANGE
Kenmore 79096229404 ELECTRIC RANGE
Kenmore 79096229406 ELECTRIC RANGE
Kenmore 79096229407 ELECTRIC RANGE
Kenmore 79096229408 ELECTRIC RANGE
Kenmore 79096229409 ELECTRIC RANGE
Kenmore 7909622940A ELECTRIC RANGE
Kenmore 7909622940B ELECTRIC RANGE
Kenmore 79096233400 ELECTRIC RANGE
Kenmore 79096312400 ELECTRIC RANGE
Kenmore 79096312401 ELECTRIC RANGE
Kenmore 79096312403 ELECTRIC RANGE
Kenmore 79096312405 ELECTRIC RANGE
Kenmore 79096312406 ELECTRIC RANGE
Kenmore 79096313400 ELECTRIC RANGE
Kenmore 79096313401 ELECTRIC RANGE
Kenmore 79096313402 ELECTRIC RANGE
Kenmore 79096313403 ELECTRIC RANGE
Kenmore 79096313405 ELECTRIC RANGE
Kenmore 79096313406 ELECTRIC RANGE
Kenmore 79096313407 ELECTRIC RANGE
Kenmore 79096314400 ELECTRIC RANGE
Kenmore 79096314401 ELECTRIC RANGE
Kenmore 79096314403 ELECTRIC RANGE
Kenmore 79096314405 ELECTRIC RANGE
Kenmore 79096314406 ELECTRIC RANGE
Kenmore 79096319400 ELECTRIC RANGE
Kenmore 79096319401 ELECTRIC RANGE
Kenmore 79096319403 ELECTRIC RANGE
Kenmore 79096319405 ELECTRIC RANGE
Kenmore 79096319406 ELECTRIC RANGE
Kenmore 79096322400 ELECTRIC RANGE
Kenmore 79096322401 ELECTRIC RANGE
Kenmore 79096322403 ELECTRIC RANGE
Kenmore 79096322405 ELECTRIC RANGE
Kenmore 79096322406 ELECTRIC RANGE
Kenmore 79096323400 ELECTRIC RANGE
Kenmore 79096323401 ELECTRIC RANGE
Kenmore 79096323402 ELECTRIC RANGE
Kenmore 79096323403 ELECTRIC RANGE
Kenmore 79096323405 ELECTRIC RANGE
Kenmore 79096323406 ELECTRIC RANGE
Kenmore 79096323407 ELECTRIC RANGE
Kenmore 79096324400 ELECTRIC RANGE
Kenmore 79096324401 ELECTRIC RANGE
Kenmore 79096324403 ELECTRIC RANGE
Kenmore 79096324405 ELECTRIC RANGE
Kenmore 79096324406 ELECTRIC RANGE
Kenmore 79096329400 ELECTRIC RANGE
Kenmore 79096329401 ELECTRIC RANGE
Kenmore 79096329403 ELECTRIC RANGE
Kenmore 79096329405 ELECTRIC RANGE
Kenmore 79096329406 ELECTRIC RANGE
Kenmore 79096332500 ELECTRIC RANGE
Kenmore 79096332501 ELECTRIC RANGE
Kenmore 79096332502 ELECTRIC RANGE
Kenmore 79096332503 ELECTRIC RANGE
Kenmore 79096332504 ELECTRIC RANGE
Kenmore 79096332505 ELECTRIC RANGE
Kenmore 79096333400 ELECTRIC RANGE
Kenmore 79096333500 ELECTRIC RANGE
Kenmore 79096333501 ELECTRIC RANGE
Kenmore 79096333502 ELECTRIC RANGE
Kenmore 79096333503 ELECTRIC RANGE
Kenmore 79096333504 ELECTRIC RANGE
Kenmore 79096333505 ELECTRIC RANGE
Kenmore 79096334500 ELECTRIC RANGE
Kenmore 79096334501 ELECTRIC RANGE
Kenmore 79096334502 ELECTRIC RANGE
Kenmore 79096334503 ELECTRIC RANGE
Kenmore 79096334504 ELECTRIC RANGE
Kenmore 79096334505 ELECTRIC RANGE
Kenmore 79096339500 ELECTRIC RANGE
Kenmore 79096339501 ELECTRIC RANGE
Kenmore 79096339502 ELECTRIC RANGE
Kenmore 79096339503 ELECTRIC RANGE
Kenmore 79096339504 ELECTRIC RANGE
Kenmore 79096339505 ELECTRIC RANGE
Kenmore 79096342500 ELECTRIC RANGE
Kenmore 79096342501 ELECTRIC RANGE
Kenmore 79096342502 ELECTRIC RANGE
Kenmore 79096342503 ELECTRIC RANGE
Kenmore 79096342504 ELECTRIC RANGE
Kenmore 79096343500 ELECTRIC RANGE
Kenmore 79096343501 ELECTRIC RANGE
Kenmore 79096343502 ELECTRIC RANGE
Kenmore 79096343503 ELECTRIC RANGE
Kenmore 79096343504 ELECTRIC RANGE
Kenmore 79096344500 ELECTRIC RANGE
Kenmore 79096344501 ELECTRIC RANGE
Kenmore 79096344502 ELECTRIC RANGE
Kenmore 79096344503 ELECTRIC RANGE
Kenmore 79096344504 ELECTRIC RANGE
Kenmore 79096349500 ELECTRIC RANGE
Kenmore 79096349501 ELECTRIC RANGE
Kenmore 79096349502 ELECTRIC RANGE
Kenmore 79096349503 ELECTRIC RANGE
Kenmore 79096349504 ELECTRIC RANGE
Kenmore 79096412400 ELECTRIC RANGE
Kenmore 79096412401 ELECTRIC RANGE
Kenmore 79096412403 ELECTRIC RANGE
Kenmore 79096412404 ELECTRIC RANGE
Kenmore 79096412406 ELECTRIC RANGE
Kenmore 79096412407 ELECTRIC RANGE
  #2 (permalink)
Old 12-29-2016, 01:02 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
If a burner/element is stuck on high, its usually the switch is shorted internally. You probably need a new one.
If I were you, I'd get the part number off the old switch and then look that up. That's the easiest way to avoid getting the wrong switch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Accessing burners on 15 yr old GE gas stove top eli978 Oven Repair (including Ranges and Cooktops) 0 03-11-2015 02:23 PM
Two top burners for Stove don't light billncrist Oven Repair (including Ranges and Cooktops) 1 06-22-2011 08:23 PM
stove top burners rbaligian Oven Repair (including Ranges and Cooktops) 0 02-06-2011 04:04 PM
Refitting gas burners on stove top FrankieZZ Oven Repair (including Ranges and Cooktops) 1 11-19-2010 09:44 AM
Kenmore Gas burners and stove will not lite gloede99 Oven Repair (including Ranges and Cooktops) 1 10-28-2008 04:59 PM
