Discuss
Oven Igniter will not activate
 in
I have a DCS stove model 70062 RGS-364GD-SS. It has a Griddle and 4 burners on the top of a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Igniter will not activate
  #1 (permalink)
Old 12-27-2016, 06:05 PM
Junior Member
MDThompson is on a distinguished road
Exclamation Oven Igniter will not activate
Model Number: 70062 RGS-364GD-SS   Brand: -other-   Age: More than 10 years
I have a DCS stove model 70062 RGS-364GD-SS. It has a Griddle and 4 burners on the top of a 36 inch oven. The oven igniter will not come on. I have replaced the igniter and the thermostat to no avail. I measure aprox. 65Vac on the leads going to the igniter, without the igniter connected. If connected, the voltage is zero. Yes, the oven has been turned on and is requesting heat, pilot light is on. The broiler portion of the oven is working correctly, as well as the griddle and surface burners. Is there anyway the Dual Valve assembly could be causing this anomaly? Thanks for any helpful information.
Related Models
Frigidaire 7007-80C ELECTRIC DRYER
Frigidaire 7007-80D ELECTRIC DRYER
Frigidaire 7007-80E ELECTRIC DRYER
Frigidaire 7007-87C ELECTRIC DRYER
Frigidaire 7007-87D ELECTRIC DRYER
Frigidaire 7007-87E ELECTRIC DRYER
Frigidaire 7007B ELECTRIC DRYER
Hoover 701
Hardwick 70131 RANGE- F/S STD GAS
Hardwick 70138 RANGE- F/S STD GAS
Maytag 701C DRYER- GAS
Hardwick 70231 RANGE- F/S STD GAS
Hardwick 70238 RANGE- F/S STD GAS
Hoover 704
Hoover 704-01
Hoover 705
Hoover 706
Hoover 707
Amana 7096 MWAVE - FAMILY SIZE (60 HZ)
Maytag 70C DRYER- GAS
Hoover 711
Amana 7121.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 714
Amana 7154.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 716
Amana 7160.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 719
Amana 7190.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 7190.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 7196 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 7198772780 Microwave Domestic
Kenmore 7198842780 MICROWAVE OVEN
Frigidaire 72-2547-00-01 Tap(v1) / Gas Range
Frigidaire 72-2547-00-02 Tap(v4) / Gas Range
Frigidaire 72-2547-00-03 Tap(v7) / Gas Range
Frigidaire 72-2547-00-04 Tap(v1) / Gas Range
Frigidaire 72-2547-00-05 Tap(v4) / Gas Range
Frigidaire 72-2547-00-06 Tap(v7) / Gas Range
Frigidaire 72-2547-00-07 Tap(v1) / Gas Range
Frigidaire 72-2547-00-08 Tap(v1) / Gas Range
Frigidaire 72-2547-00-09 Tap(v1) / Gas Range
Frigidaire 72-2547-23-01 Tap(v2) / Gas Range
Frigidaire 72-2547-23-02 Tap(v5) / Gas Range
Frigidaire 72-2547-23-03 Tap(v8) / Gas Range
Frigidaire 72-2547-23-04 Tap(v2) / Gas Range
Frigidaire 72-2547-23-05 Tap(v5) / Gas Range
Frigidaire 72-2547-23-06 Tap(v8) / Gas Range
Frigidaire 72-2547-23-07 Tap(v2) / Gas Range
Frigidaire 72-2547-23-08 Tap(v2) / Gas Range
Frigidaire 72-2547-23-09 Tap(v2) / Gas Range
Frigidaire 72-2547-66-01 Tap(v3) / Gas Range
Frigidaire 72-2547-66-02 Tap(v6) / Gas Range
Frigidaire 72-2547-66-03 Tap(v9) / Gas Range
Frigidaire 72-2547-66-04 Tap(v3) / Gas Range
Frigidaire 72-2547-66-05 Tap(v6) / Gas Range
Frigidaire 72-2547-66-06 Tap(v9) / Gas Range
Frigidaire 72-2547-66-07 Tap(v3) / Gas Range
Frigidaire 72-2547-66-08 Tap(v3) / Gas Range
Frigidaire 72-2547-66-09 Tap(v3) / Gas Range
Tappan 72-3651-00 RANGE
Frigidaire 72-3651-00-01 Tap(v1) / Gas Range
Frigidaire 72-3651-00-02 Tap(v1) / Gas Range
Frigidaire 72-3651-00-03 Tap(v3) / Gas Range
Frigidaire 72-3651-00-04 Tap(v1) / Gas Range
Frigidaire 72-3651-00-05 Tap(v1) / Gas Range
Frigidaire 72-3651-00-06 Tap(v1) / Gas Range
Frigidaire 72-3651-00-07 Tap(v2) / Gas Range
Frigidaire 72-3651-00-08 Tap(v1) / Gas Range
Tappan 72-3651-01 RANGE
Frigidaire 72-3651-23-01 Tap(v2) / Gas Range
Frigidaire 72-3651-23-02 Tap(v2) / Gas Range
Frigidaire 72-3651-23-03 Tap(v4) / Gas Range
Frigidaire 72-3651-23-04 Tap(v2) / Gas Range
Frigidaire 72-3651-23-05 Tap(v2) / Gas Range
Frigidaire 72-3651-23-06 Tap(v3) / Gas Range
Frigidaire 72-3651-23-07 Tap(v4) / Gas Range
Frigidaire 72-3651-23-08 Tap(v2) / Gas Range
Frigidaire 72-3657-00-01 Tap(v1) / Gas Range
Frigidaire 72-3657-00-02 Tap(v4) / Gas Range
Frigidaire 72-3657-00-03 Tap(v1) / Gas Range
Frigidaire 72-3657-00-04 Tap(v4) / Gas Range
Frigidaire 72-3657-00-05 Tap(v1) / Gas Range
Frigidaire 72-3657-00-06 Tap(v7) / Gas Range
Frigidaire 72-3657-00-07 Tap(v1) / Gas Range
Frigidaire 72-3657-00-08 Tap(v1) / Gas Range
Frigidaire 72-3657-00-09 Tap(v7) / Gas Range
Frigidaire 72-3657-00-10 Tap(v1) / Gas Range
Frigidaire 72-3657-00-11 Tap(v4) / Gas Range
Frigidaire 72-3657-00-12 Tap(v7) / Gas Range
Frigidaire 72-3657-00-13 Tap(v1) / Gas Range
Frigidaire 72-3657-23-01 Tap(v2) / Gas Range
Frigidaire 72-3657-23-02 Tap(v5) / Gas Range
Frigidaire 72-3657-23-03 Tap(v2) / Gas Range
Frigidaire 72-3657-23-04 Tap(v5) / Gas Range
Frigidaire 72-3657-23-05 Tap(v2) / Gas Range
Frigidaire 72-3657-23-06 Tap(v8) / Gas Range
Frigidaire 72-3657-23-07 Tap(v2) / Gas Range
Frigidaire 72-3657-23-08 Tap(v2) / Gas Range
Frigidaire 72-3657-23-09 Tap(v8) / Gas Range
Frigidaire 72-3657-23-10 Tap(v2) / Gas Range
Frigidaire 72-3657-23-11 Tap(v5) / Gas Range
Frigidaire 72-3657-23-12 Tap(v8) / Gas Range
Frigidaire 72-3657-23-13 Tap(v2) / Gas Range
Frigidaire 72-3657-66-01 Tap(v3) / Gas Range
Frigidaire 72-3657-66-02 Tap(v6) / Gas Range
Frigidaire 72-3657-66-03 Tap(v3) / Gas Range
Frigidaire 72-3657-66-04 Tap(v6) / Gas Range
Frigidaire 72-3657-66-05 Tap(v3) / Gas Range
Frigidaire 72-3657-66-06 Tap(v9) / Gas Range
Frigidaire 72-3657-66-07 Tap(v3) / Gas Range
Frigidaire 72-3657-66-08 Tap(v3) / Gas Range
Frigidaire 72-3657-66-09 Tap(v9) / Gas Range
Frigidaire 72-3657-66-10 Tap(v3) / Gas Range
Frigidaire 72-3657-66-11 Tap(v6) / Gas Range
Frigidaire 72-3657-66-12 Tap(v9) / Gas Range
Frigidaire 72-3657-66-13 Tap(v3) / Gas Range
Frigidaire 72-3662-00-01 Tap(v1) / Gas Range
Frigidaire 72-3662-23-01 Tap(v2) / Gas Range
Frigidaire 72-3977-00-01 Tap(v1) / Gas Range
Frigidaire 72-3977-00-02 Tap(v4) / Gas Range
  #2 (permalink)
Old 12-29-2016, 02:36 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Your model number isn't working for me.
Yes, the valve could be the problem, there might be a thermal cutout/fuse that went out too.
I'd put the ignitor back in circuit. turn the oven to bake and see if the ignitor glows. If it doesn't, I'd check the voltage to it. It should be 120 volts AC. (I know you said you measured 65V)
The power comes in from the cord, goes through the thermostat, thermal fuse (if there is one) through the ignitor, then through the gas valve and back to the cord.
Its a series circuit. A break or bad connection anywhere will stop it. The parts might not be wired exactly like I described it, but you get the idea.
So if the power is partly or completely missing, you need to find where its not getting through.
Unplug you range and take the wires off the gas valve. Put your test probes across the gas valves two terminals, you should read low ohm reading of about 5 ohms or so. If its an open circuit its bad. If its a really high ohm reading its bad.
A short video that might help.
https://www.youtube.com/watch?v=-RZtxSvOe-U
  #3 (permalink)
Old 12-29-2016, 03:30 PM
Junior Member
Smile Parts on order
Thanks for the information. I have ordered the Dual Safety Valve from FISHER & PAYKEL APPLIANCES, the company that now owns (DCS) Dynamic Cooking Systems. This company is located in New Zealand. This has been a chore finding out who the original manufacturer was. It has a JENN-AIR badge but was made by DCS, who would have guessed.
Thanks Again for the information.
  #4 (permalink)
Old 12-31-2016, 06:55 AM
Junior Member
Default
Dual Control Valve installed and the oven is now functional. The resistance across the oven terminals was 200meg ohms, and the broiler was 0 ohms. Thanks Again for the assistance.
  #5 (permalink)
Old 12-31-2016, 05:45 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
I'm glad you got it working.
You're welcome and Happy New Year!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor will not activate Scfitch Trash Compactor Repair 1 06-23-2015 01:20 PM
manually activate defrost wapiwulo Refrigerator & Freezer Repair 1 12-28-2014 09:47 AM
Whirlpool oven start button won't activate colejster Oven Repair (including Ranges and Cooktops) 3 11-26-2012 03:01 PM
Turntable Won't Activate Curtise Microwave Repair 1 06-21-2011 06:43 PM
Oven Self Clean won't activate kbrisson Oven Repair (including Ranges and Cooktops) 0 01-22-2011 07:54 PM
