Discuss
Jenn-air gas oven
 in
My Jenn-air gas oven just stopped heating up on bake mode. The Broiler mantel lights up and works good. The
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-air gas oven
  #1 (permalink)
Old 12-19-2016, 02:21 PM
Junior Member
joeysgrandpa is on a distinguished road
Default Jenn-air gas oven
Model Number: JGW8130ADB   Brand: Jenn-Air   Age: More than 10 years
The Broiler mantel lights up and works good. The bake mantel igniter lights up but no gas is coming out of the mantel. can someone give me some suggestions?
Harold
Related Models
Jenn-Air JGW8130ADB WALLOVEN- S/C GAS
Jenn-Air JGW8130ADW WALLOVEN- S/C GAS
Jenn-Air JGW8130DDB WALLOVEN- S/C GAS
Maytag JGW8130DDB12 30" BUILT-IN GAS SINGLE OVEN
Maytag JGW8130DDB15 30" BUILT-IN GAS SINGLE OVEN
Jenn-Air JGW8130DDW WALLOVEN- S/C GAS
Maytag JGW8130DDW12 30" BUILT-IN GAS SINGLE OVEN
Maytag JGW8130DDW15 30" BUILT-IN GAS SINGLE OVEN
Jenn-Air JGW9130ADB WALLOVEN- S/C GAS
Jenn-Air JGW9130ADW WALLOVEN- S/C GAS
General Electric JHC56*D1 Hi-low range
General Electric JHC56*VA Hi-low range
General Electric JHC56*VB Hi-low range
General Electric JHC56G*D1 Hi-low range
General Electric JHC56G*D2 Hi-low range
Maytag JHP1060 JADE HOT PLATES (COOKING GAS)
Maytag JHP112 JHP HOT PLATE (COOKING GAS)
Maytag JHP212 JHP HOT PLATE (COOKING GAS)
Maytag JHP224 JHP HOT PLATE (COOKING GAS)
Maytag JHP336 JHP HOT PLATE (COOKING GAS)
Maytag JHP424 JHP HOT PLATE (COOKING GAS)
Maytag JHP448 JADE HOT PLATES (COOKING GAS)
General Electric JHP56*D1 Hi-low range
General Electric JHP56*V8 Hi-low range
General Electric JHP56*VA Hi-low range
General Electric JHP56G*C1 Hi-low range
General Electric JHP56G*D1 Hi-low range
General Electric JHP56G*D2 Hi-low range
General Electric JHP56G*D3 Hi-low range
General Electric JHP56G*H1 GE HI/LOW COOKING CENTER
General Electric JHP56G*H2 Hi-low range
General Electric JHP56G*J1 Hi-low range
General Electric JHP56G*J2 Hi-low range
General Electric JHP56G*J3 Hi-low range
General Electric JHP56G*M1 Hi-low range
General Electric JHP56G*V6 Hi-low range
General Electric JHP56GN1 Hi-low range
General Electric JHP56GN2 Hi-low range
General Electric JHP56GN3AD Electric range
General Electric JHP56GN3WH Electric range
General Electric JHP56GN4AD Electric range
General Electric JHP56GN4WH Electric range
General Electric JHP56GN5AD Electric range
General Electric JHP56GN5WH Electric range
General Electric JHP56GN6AD Electric range
General Electric JHP56GN6WH Electric range
General Electric JHP56GN7AD Electric range
General Electric JHP56GN7WH Electric range
General Electric JHP56N*K1 Hi-low range
General Electric JHP56N*K2 Hi-low range
General Electric JHP56N*K3 Hi-low range
General Electric JHP56N*K4 Hi-low range
General Electric JHP56V*K1 Hi-low range
General Electric JHP56V*K2 Hi-low range
General Electric JHP56V*K3 Hi-low range
General Electric JHP56V*K4 Hi-low range
General Electric JHP60G*01 Hi-low range
General Electric JHP60G*02 Hi-low range
General Electric JHP60G*03 Hi-low range
General Electric JHP60G*04 Hi-low range
General Electric JHP61G*H2 Hi-low range
General Electric JHP61G*J1 Hi-low range
General Electric JHP62G*M1 Hi-low range
General Electric JHP62GN1 Electric range
General Electric JHP62GN2 Hi-low range
General Electric JHP62GN3AD Electric range
General Electric JHP62GN3WH Electric range
General Electric JHP62GN4AD Electric range
General Electric JHP62GN4WH Electric range
General Electric JHP62GN5AD Electric range
General Electric JHP62GN5WH Electric range
General Electric JHP62GN6AD Electric range
General Electric JHP62GN6WH Electric range
General Electric JHP62N*K1 Hi-low range
General Electric JHP62N*K2 Hi-low range
General Electric JHP62N*K3 Hi-low range
General Electric JHP62N*K4 Hi-low range
General Electric JHP62N*K5 Hi-low range
General Electric JHP62V*K1 Hi-low range
General Electric JHP62V*K2 Hi-low range
General Electric JHP62V*K3 Hi-low range
General Electric JHP62V*K4 Hi-low range
General Electric JHP62V*K5 Hi-low range
Maytag JHP636 JADE HOT PLATES (COOKING GAS)
General Electric JHP63G*H1 Hi-low range
General Electric JHP63G*J1 Hi-low range
General Electric JHP63G*J2 Hi-low range
General Electric JHP63G*J3 Hi-low range
General Electric JHP63G*M1 Hi-low range
General Electric JHP63GN1 Electric range
General Electric JHP63GN2 Hi-low range
General Electric JHP63GN3AD Electric range
General Electric JHP63GN3WH Electric range
General Electric JHP63GN4AD Electric range
General Electric JHP63GN4WH Electric range
General Electric JHP63GN5AD Electric range
General Electric JHP63GN5WH Electric range
General Electric JHP63V*K1 Hi-low range
General Electric JHP63V*K2 Hi-low range
General Electric JHP63V*K3 Hi-low range
General Electric JHP63V*K4 Hi-low range
General Electric JHP63V*K5 Hi-low range
General Electric JHP64G*L1 Hi-low range
General Electric JHP64V*L1 Hi-low range
General Electric JHP65G*01 Hi-low range
General Electric JHP65G*02 Hi-low range
General Electric JHP65G*D1 Hi-low range
General Electric JHP66G*01 Hi-low range
General Electric JHP66G*02 Hi-low range
General Electric JHP67G*D1 Hi-low range
General Electric JHP67G*D2 Hi-low range
General Electric JHP67G*D3 Hi-low range
General Electric JHP67G*H1 GE HI/LOW COOKING CENTER
General Electric JHP67G*H2 Hi-low range
General Electric JHP67G*V5 Hi-low range
General Electric JHP68G*01 Hi-low range
General Electric JHP68G*02 Hi-low range
General Electric JHP69G*H2 Hi-low range
General Electric JHP69G*J1 Hi-low range
General Electric JHP69G*K1 Hi-low range
  #2 (permalink)
Old 12-20-2016, 11:05 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
The ignitor could be weak, if you had a clamp on amp meter you could test it.. To open the gas valve the ignitor has to pull 3.2 to 3.6 amps.
Sometimes (when they are weak) you can get them to lite by very lightly tapping on the gas valve with the handle of a screwdriver. This would be after the ignitor had reached its maximum brightness.
Its just a temporary test. Then you need to change out the ignitor.
Whirlpool 12400035 Flat Style Oven Igniter Kit - AppliancePartsPros.com
  #3 (permalink)
Old 12-21-2016, 09:51 AM
Junior Member
Default
Thanks,
I did see the info on the weak igniter being a possible cause, but it was hard to tell just looking at it. there are 4 sections of the igniter filament and only the inner 2 are glowing yellow. the outer 2 are red to dark red.
Is it possible to test/replace the igniter without getting into the back of the oven?
  #4 (permalink)
Old 12-21-2016, 11:01 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
The ignitor should glow so bright that you won't want to look at it.
I'd say that yours is bad. They don't cost too much, so order one and replace it and I'll bet your oven will work again.
Just be careful with the ignitors. They are very sensitive to vibration. Don't touch the part that glows (your skin oils will cause it to fail.)
Good luck with it.
  #5 (permalink)
Old 12-21-2016, 03:41 PM
Junior Member
Default
Thanks! I measured the current with an inductive pickup and measured 2.14A at the igniter than does not work and 3.15A for the broiler mantel which works. I ordered the igniter so I should have it by saturday or so.
I saw some other sources of the igniter and some have ceramic wire nuts instead of the connector. Is there a way to install the igniter using wire nuts so I dont need to pull the oven from its cabinet to access the connector
  #6 (permalink)
Old 12-21-2016, 07:13 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
This kit comes with wire nuts and extra wires. Watch the video and it will help you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Aire Micro/Oven combo, oven door does not shut tight dsazama Oven Repair (including Ranges and Cooktops) 6 07-25-2015 10:37 PM
Jenn-air double wall oven - lower oven will not turn on hjustice Oven Repair (including Ranges and Cooktops) 1 09-29-2014 02:35 AM
Jenn Air Convection Wall Oven lower oven will not stay on Flightlessbird Oven Repair (including Ranges and Cooktops) 0 12-18-2013 10:12 AM
Oven lock switch on Jenn-Air electric oven miriamgreen Oven Repair (including Ranges and Cooktops) 0 10-21-2009 01:40 PM
jenn-air oven display blank but oven works fine elyot450 Oven Repair (including Ranges and Cooktops) 2 07-04-2009 01:44 PM
