Discuss
No power to one of the broiler lads
 in
I have a technical question about my Model #79046712603 KENMORE ELITE Slide-In Range, Electric. The broiler does not work. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No power to one of the broiler lads
  #1 (permalink)
Old 12-19-2016, 11:16 AM
Junior Member
Steemrlr is on a distinguished road
Default No power to one of the broiler lads
Model Number: 79046712603   Brand: Kenmore   Age: 5 - 10 years
I have a technical question about my Model #79046712603 KENMORE ELITE Slide-In Range, Electric. The broiler does not work. I removed it and it ohm checks properly at 14 ohms. I removed the two blue leads and after turning on the broiler, one lead measures 120 Vac and the other 0-vac. However, there is 240vac at the incoming terminals. Q: What do you think is the cause of the malfunction? Thanks
Background: We experienced a "runaway" broiler that cremated the top of a pie we were cooking, but surmised we must have put in on broiler vs bake....We thought it worked okay later, but then when using broil, it did not work, then kicked in for awhile, then failed altogether....now it only has 120vac to the one lead, not the other. There is 240 at the terminals.
Related Models
Kenmore 79046712603 ELECTRIC RANGE
Kenmore 79046713601 ELECTRIC RANGE
Kenmore 79046713602 ELECTRIC RANGE
Kenmore 79046713603 ELECTRIC RANGE
Kenmore 79046713604 ELECTRIC RANGE
Kenmore 79046713605 ELECTRIC RANGE
Kenmore 79046714600 ELECTRIC RANGE
Kenmore 79046714601 ELECTRIC RANGE
Kenmore 79046714602 ELECTRIC RANGE
Kenmore 79046714603 ELECTRIC RANGE
Kenmore 79046719600 ELECTRIC RANGE
Kenmore 79046719601 ELECTRIC RANGE
Kenmore 79046719602 ELECTRIC RANGE
Kenmore 79046719603 ELECTRIC RANGE
Kenmore 79046722700 ELECTRIC RANGE
Kenmore 79046723700 ELECTRIC RANGE
Kenmore 79046723701 ELECTRIC RANGE
Kenmore 79046729700 ELECTRIC RANGE
Kenmore 79046762900 ELECTRIC RANGE
Kenmore 79046762901 ELECTRIC RANGE
Kenmore 79046762902 ELECTRIC RANGE
Kenmore 79046762903 ELECTRIC RANGE
Kenmore 79046763900 RANGE
Kenmore 79046763901 ELECTRIC RANGE
Kenmore 79046763902 ELECTRIC RANGE
Kenmore 79046763903 ELECTRIC RANGE
Kenmore 79046764900 ELECTRIC RANGE
Kenmore 79046764901 ELECTRIC RANGE
Kenmore 79046764902 ELECTRIC RANGE
Kenmore 79046764903 ELECTRIC RANGE
Kenmore 79046769900 ELECTRIC RANGE
Kenmore 79046769901 ELECTRIC RANGE
Kenmore 79046769902 ELECTRIC RANGE
Kenmore 79046769903 ELECTRIC RANGE
Kenmore 79046781900 ELECTRIC RANGE
Kenmore 79046781901 ELECTRIC RANGE
Kenmore 79046781902 ELECTRIC RANGE
Kenmore 79046781903 ELECTRIC RANGE
Kenmore 79046782900 ELECTRIC RANGE
Kenmore 79046782901 ELECTRIC RANGE
Kenmore 79046782902 ELECTRIC RANGE
Kenmore 79046782903 ELECTRIC RANGE
Kenmore 79046783900 ELECTRIC RANGE
Kenmore 79046783901 ELECTRIC RANGE
Kenmore 79046783902 ELECTRIC RANGE
Kenmore 79046783903 ELECTRIC RANGE
Kenmore 79046784900 ELECTRIC RANGE
Kenmore 79046784901 ELECTRIC RANGE
Kenmore 79046784902 ELECTRIC RANGE
Kenmore 79046784903 ELECTRIC RANGE
Kenmore 79046789900 ELECTRIC RANGE
Kenmore 79046789901 ELECTRIC RANGE
Kenmore 79046789902 ELECTRIC RANGE
Kenmore 79046789903 ELECTRIC RANGE
Kenmore 79046802990 ELECTRIC SLIDE-IN RANGE
Kenmore 79046802991 ELECTRIC SLIDE IN RANGE
Kenmore 79046802992 ELECTRIC SLIDE-IN RANGE
Kenmore 79046802993 RANGE
Kenmore 79046803990 ELECTRIC SLIDE-IN RANGE
Kenmore 79046803991 ELECTRIC SLIDE-IN RANGE
Kenmore 79046803992 ELECTRIC SLIDE-IN RANGE
Kenmore 79046803993 RANGE
Kenmore 79046804990 ELECTRIC SLIDE-IN RANGE
Kenmore 79046804991 ELECTRIC SLIDE IN RANGE
Kenmore 79046804992 ELECTRIC SLIDE-IN RANGE
Kenmore 79046804993 RANGE
Kenmore 79046809990 ELECTRIC SLIDE-IN RANGE
Kenmore 79046809991 ELECTRIC SLIDE IN RANGE
Kenmore 79046809992 ELECTRIC SLIDE-IN RANGE
Kenmore 79046809993 RANGE
Kenmore 79046812990 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046812991 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046812992 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046812993 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046813990 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046813991 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046813992 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046813993 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046814990 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046814992 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046814993 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046819990 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046819992 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046819993 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046822100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046822101 SLIDE-IN RANGE
Kenmore 79046822102 SEARS/ELECTRIC RANGE
Kenmore 79046823100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046823101 SEARS/ELECTRIC RANGE
Kenmore 79046823102 SEARS/ELECTRIC RANGE
Kenmore 79046824100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046824101 SLIDE-IN RANGE
Kenmore 79046824102 SEARS/ELECTRIC RANGE
Kenmore 79046829100 ELECTRIC SLIDE-IN RANGE
Kenmore 79046829101 SLIDE-IN RANGE
Kenmore 79046829102 SEARS/ELECTRIC RANGE
Kenmore 79046832100 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046832101 SEARS/GAS RANGE
Kenmore 79046832102 SEARS/GAS RANGE
Kenmore 79046833100 DUAL FUEL RANGE
Kenmore 79046833101 SEARS/GAS RANGE
Kenmore 79046833102 SEARS/GAS RANGE
Kenmore 79046834100 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046834101 SEARS/GAS RANGE
Kenmore 79046834102 SEARS/GAS RANGE
Kenmore 79046839100 DUAL FUEL SLIDE-IN RANGE
Kenmore 79046839101 SEARS/GAS RANGE
Kenmore 79046839102 SEARS/GAS RANGE
Kenmore 79046892900 ELECTRIC RANGE
Kenmore 79046892901 ELECTRIC RANGE
Kenmore 79046892902 ELECTRIC RANGE
Kenmore 79046892903 ELECTRIC RANGE
Kenmore 79046893900 ELECTRIC RANGE
Kenmore 79046893901 ELECTRIC RANGE
Kenmore 79046893902 ELECTRIC RANGE
Kenmore 79046893903 ELECTRIC RANGE
Kenmore 79046899900 ELECTRIC RANGE
Kenmore 79046899901 ELECTRIC RANGE
Kenmore 79046899902 ELECTRIC RANGE
Kenmore 79046899903 ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no power to broiler igniter bigd101 Oven Repair (including Ranges and Cooktops) 2 01-15-2013 08:20 PM
Lost power Jenn Air dual feul double oven - power won't return my jenn air Oven Repair (including Ranges and Cooktops) 1 11-08-2011 05:46 AM
Replaced broiler element, broiler still won't heat wdanb Oven Repair (including Ranges and Cooktops) 1 06-16-2011 01:14 PM
oven and broiler igniter not getting any power solutionman Oven Repair (including Ranges and Cooktops) 4 12-10-2010 03:42 PM
power surge damaged power pack,replaced,compressor and condenser fan still not runnin shillion Refrigerator & Freezer Repair 0 11-16-2010 01:38 AM
