Discuss
Can Broil but can not bake Frigidaire Range
 in
The oven in this range just stopped working for no apparent reason. I checked continuity on the bake element and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Can Broil but can not bake Frigidaire Range
  #1 (permalink)
Old 12-13-2016, 03:20 PM
BnJ BnJ is offline
Junior Member
BnJ is on a distinguished road
Question Can Broil but can not bake Frigidaire Range
Model Number: FEF336BGWD   Brand: Frigidaire   Age: 5 - 10 years
The oven in this range just stopped working for no apparent reason. I checked continuity on the bake element and its fine. So I first replaced the Infinite switch with no change. So I then replaced the Tnermostat/Switch and still no change. So even though the element tested OK, I replaced it and still no oven bake. I can broil just fine.
If I turn the thermostat switch or the Infinite Switch to BROIL I get the oven on indicator light. However that light never comes on in any bake setting. I have looked at the wiring diagram and do not see any additional relays/components that could be effecting this.
Any ideas ? I'm out of them.
BnJ
Related Models
Frigidaire FEF336BGWD Frg(v0) / Electric Range
Frigidaire FEF336BGWF Frigidaire/electric Range
Frigidaire FEF336ECA Frigidaire/electric Range
Frigidaire FEF336ECB Frigidaire/electric Range
Frigidaire FEF336ECC Frigidaire/range
Frigidaire FEF336ECD Frigidaire/range
Frigidaire FEF336ECE Frigidaire/range
Frigidaire FEF336ECF Frigidaire/electric Range
Frigidaire FEF336ECG ELECTRIC RANGE
Frigidaire FEF336ECH ELECTRIC RANGE
Frigidaire FEF336ECJ ELECTRIC RANGE
Frigidaire FEF336ECK ELECTRIC RANGE
Frigidaire FEF336ECM ELECTRIC RANGE
Frigidaire FEF336ECX ELECTRIC RANGE
Frigidaire FEF336ESA Frigidaire/electric Range
Frigidaire FEF336ESB Frigidaire/electric Range
Frigidaire FEF336ESC Frigidaire/range
Frigidaire FEF336ESD ELECTRIC RANGE
Frigidaire FEF336FMA Frigidaire/electric Range
Frigidaire FEF336FMB Frigidaire/range
Frigidaire FEF336FMC Frigidaire/range
Frigidaire FEF336FMD ELECTRIC RANGE
Frigidaire FEF336FME ELECTRIC RANGE
Frigidaire FEF336FMF ELECTRIC RANGE
Frigidaire FEF336WHSA Frg(v1) / Electric Range
Frigidaire FEF336WHSB Frg(v2) / Electric Range
Frigidaire FEF336WHSC Frigidaire/electric Range
Frigidaire FEF336WHSD Frigidaire/electric Range
Frigidaire FEF337BADA Frg(v2) / Electric Range
Frigidaire FEF337BADB Frg(v1) / Electric Range
Frigidaire FEF337BAWA Frg(v1) / Electric Range
Frigidaire FEF337BAWB Frg(v2) / Electric Range
Frigidaire FEF339ESA Frigidaire/range
Frigidaire FEF339ESB Frigidaire/range
Frigidaire FEF339ESC Frigidaire/range
Frigidaire FEF339FSA Frigidaire/range
Frigidaire FEF339FSB Frigidaire/electric Range
Frigidaire FEF339FSC Frigidaire/range
Frigidaire FEF339FSD ELECTRIC RANGE
Frigidaire FEF339FSE ELECTRIC RANGE
Frigidaire FEF339LCA ELECTRIC RANGE
Frigidaire FEF339LCB ELECTRIC RANGE
Frigidaire FEF342BADA Frg(v2) / Electric Range
Frigidaire FEF342BADB Frg(v3) / Electric Range
Frigidaire FEF342BAWA Frg(v1) / Electric Range
Frigidaire FEF342BAWB Frg(v2) / Electric Range
Frigidaire FEF350BADA Frg(v2) / Electric Range
Frigidaire FEF350BADB Frg(v2) / Electric Range
Frigidaire FEF350BADC Frg(v1) / Electric Range
Frigidaire FEF350BADD Frg(v2) / Electric Range
Frigidaire FEF350BADE Frg(v3) / Electric Range
Frigidaire FEF350BADF Frg(v1) / Electric Range
Frigidaire FEF350BADG Frg(v1) / Electric Range
Frigidaire FEF350BADH Frg(v1) / Electric Range
Frigidaire FEF350BAWA Frg(v1) / Electric Range
Frigidaire FEF350BAWB Frg(v1) / Electric Range
Frigidaire FEF350BAWC Frg(v3) / Electric Range
Frigidaire FEF350BAWD Frg(v4) / Electric Range
Frigidaire FEF350BAWE Frg(v4) / Electric Range
Frigidaire FEF350BAWF Frg(v2) / Electric Range
Frigidaire FEF350BAWG Frg(v2) / Electric Range
Frigidaire FEF350BAWH Frg(v2) / Electric Range
Frigidaire FEF350BEDA Frg(v1) / Electric Range
Frigidaire FEF350BEDB Frg(v1) / Electric Range
Frigidaire FEF350BEWA Frg(v2) / Electric Range
Frigidaire FEF350BEWB Frg(v2) / Electric Range
Frigidaire FEF350CADA Frg(v2) / Electric Range
Frigidaire FEF350CADB Frg(v1) / Electric Range
Frigidaire FEF350CASA Frg(v1) / Electric Range
Frigidaire FEF350CASB Frg(v2) / Electric Range
Frigidaire FEF350CASC Frg(v5) / Electric Range
Frigidaire FEF350CASD Frg(v6) / Electric Range
Frigidaire FEF350CASE Frg(v5) / Electric Range
Frigidaire FEF350CASF Frg(v3) / Electric Range
Frigidaire FEF350CASG Frg(v3) / Electric Range
Frigidaire FEF350CASH Frg(v3) / Electric Range
Frigidaire FEF350CAWA Frg(v1) / Electric Range
Frigidaire FEF350CAWB Frg(v3) / Electric Range
Frigidaire FEF350CCTA Frg(v1) / Electric Range
Frigidaire FEF350CCTB Frg(v2) / Electric Range
Frigidaire FEF350CCTC Frg(v0) / Electric Range
Frigidaire FEF350CCTD Frg(v0) / Electric Range
Frigidaire FEF350CCTE Frg(v0) / Electric Range
Frigidaire FEF350CCTF Frg(v0) / Electric Range
Frigidaire FEF350CESA Frg(v3) / Electric Range
Frigidaire FEF350CESB Frg(v3) / Electric Range
Frigidaire FEF350CETA Frg(v4) / Electric Range
Frigidaire FEF350CETB Frg(v4) / Electric Range
Frigidaire FEF350SADA Frg(v2) / Electric Range
Frigidaire FEF350SADB Frg(v1) / Electric Range
Frigidaire FEF350SADC Frg(v1) / Electric Range
Frigidaire FEF350SADD Frg(v1) / Electric Range
Frigidaire FEF350SADE Frg(v1) / Electric Range
Frigidaire FEF350SADF Frg(v4) / Electric Range
Frigidaire FEF350SADG Frg(v4) / Electric Range
Frigidaire FEF350SADH Frg(v4) / Electric Range
Frigidaire FEF350SADJ Frg(v1) / Electric Range
Frigidaire FEF350SAWA Frg(v1) / Electric Range
Frigidaire FEF350SAWB Frg(v2) / Electric Range
Frigidaire FEF350SAWC Frg(v2) / Electric Range
Frigidaire FEF350SAWD Frg(v2) / Electric Range
Frigidaire FEF350SAWE Frg(v2) / Electric Range
Frigidaire FEF350SAWF Frg(v5) / Electric Range
Frigidaire FEF350SAWG Frg(v5) / Electric Range
Frigidaire FEF350SAWH Frg(v5) / Electric Range
Frigidaire FEF350SAWJ Frg(v2) / Electric Range
Frigidaire FEF350XAWA Frg(v1) / Electric Range
Frigidaire FEF351CSA Frigidaire/electric Range
Frigidaire FEF351CSB Frigidaire/electric Range
Frigidaire FEF351CSC Frigidaire/electric Range
Frigidaire FEF351CUA Frigidaire/electric Range
Frigidaire FEF351CUB Frigidaire/electric Range
Frigidaire FEF351CUC Frigidaire/electric Range
Frigidaire FEF351CWA Frigidaire/electric Range
Frigidaire FEF351CWB Frigidaire/electric Range
Frigidaire FEF351CWC Frigidaire/electric Range
Frigidaire FEF351SADA Frg(v2) / Electric Range
Frigidaire FEF351SADB Frg(v1) / Electric Range
Frigidaire FEF351SAWA Frg(v1) / Electric Range
Frigidaire FEF351SAWB Frg(v2) / Electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No bake, no broil on Whirlpool range. Help! JamesTheScot Oven Repair (including Ranges and Cooktops) 1 08-14-2015 12:35 AM
Kenmore range: no bake / broil BPSOswego Oven Repair (including Ranges and Cooktops) 0 10-01-2014 03:40 PM
Kenmore Gas Range - bake and broil not working makemyovenwork Oven Repair (including Ranges and Cooktops) 0 11-25-2013 04:21 PM
Frigidaire Range...no bake or broil JeffD Oven Repair (including Ranges and Cooktops) 1 11-03-2009 06:03 PM
No Bake or Broil Gas Amana Range MoeMan Oven Repair (including Ranges and Cooktops) 2 02-20-2009 07:43 AM
