I have a Whirlpool GS773LXSSO gas range with an intermittent oven problem. The first time you press bake and start, the burner comes on and heats up to the set point and turns off. It will usually come back on once or twice to keep the temp & then it never comes back on. If you then press bake and start again it usually comes on & starts this all over again. The Temp sensor reads 1073 ohms @ 65 deg. on bench Gas Valve on oven with wires removed reads 193.6 ohm @ terminals where blue & orange wires go & 190.8 ohms @ terminals where orange & red wires go. Are those far enough away from 216 to be causing my problem ? or ?? Thanks - Steve
