No bake, igniter and valve have continuity..stumped
Hello, Bake stopped working on my Kenmore oven. I replaced the igniter without even testing anything since it seemed so
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No bake, igniter and valve have continuity..stumped
  #1 (permalink)
Old 12-07-2016, 01:42 PM
Junior Member
Breene is on a distinguished road
Angry No bake, igniter and valve have continuity..stumped
Model Number: 79079363405   Brand: Kenmore   Age: 5 - 10 years
Bake stopped working on my Kenmore oven. I replaced the igniter without even testing anything since it seemed so common, that wasn't the problem.
Tested both new and old igniters, both have continuity. Pulled out the safety valve and both the broil (which works) and bake side (not working) have continuity - I was hoping this test would fail so I would know whats wrong.
Now I'm confused. I tested it with things turned on, the broil side of the valve does get current to it's two wires when turned on.
When bake is on, there is no current on the valve. Does this still mean bad valve, or is it a control board or something worse ?
Thanks for any thoughts...
Related Models
Kenmore 79079363405 GAS RANGE
Kenmore 79079363406 GAS RANGE
Kenmore 79079364400 GAS RANGE
Kenmore 79079364402 GAS RANGE
Kenmore 79079364405 GAS RANGE
Kenmore 79079364406 GAS RANGE
Kenmore 79079369400 GAS RANGE
Kenmore 79079369402 GAS RANGE
Kenmore 79079369405 GAS RANGE
Kenmore 79079369406 GAS RANGE
Kenmore 79079372400 GAS RANGE
Kenmore 79079372402 GAS RANGE
Kenmore 79079372405 RANGE
Kenmore 79079372406 GAS RANGE
Kenmore 79079373400 GAS RANGE
Kenmore 79079373401 GAS RANGE
Kenmore 79079373402 GAS RANGE
Kenmore 79079373404 RANGE
Kenmore 79079373405 GAS RANGE
Kenmore 79079373406 GAS RANGE
Kenmore 79079374400 GAS RANGE
Kenmore 79079374402 GAS RANGE
Kenmore 79079374405 RANGE
Kenmore 79079374406 GAS RANGE
Kenmore 79079379400 GAS RANGE
Kenmore 79079379402 GAS RANGE
Kenmore 79079379405 RANGE
Kenmore 79079379406 GAS RANGE
Kenmore 79079382400 DUEL FUEL RANGE
Kenmore 79079382402 DUAL FUEL RANGE
Kenmore 79079382405 DUAL FUEL RANGE
Kenmore 79079382406 DUAL FUEL RANGE
Kenmore 79079383400 DUAL FUEL RANGE
Kenmore 79079383401 DUAL FUEL RANGE
Kenmore 79079383402 DUAL FUEL RANGE
Kenmore 79079383404 DUAL FUEL RANGE
Kenmore 79079383405 DUAL FUEL RANGE
Kenmore 79079383406 DUAL FUEL RANGE
Kenmore 79079384400 DUEL FUEL RANGE
Kenmore 79079384402 DUAL FUEL RANGE
Kenmore 79079384405 DUAL FUEL RANGE
Kenmore 79079384406 DUAL FUEL RANGE
Kenmore 79079389400 DUEL FUEL RANGE
Kenmore 79079389402 DUAL FUEL RANGE
Kenmore 79079389405 DUAL FUEL RANGE
Kenmore 79079389406 DUAL FUEL RANGE
Kenmore 79079422600 GAS RANGE
Kenmore 79079422601 GAS RANGE
Kenmore 79079422602 GAS RANGE
Kenmore 79079423600 GAS RANGE
Kenmore 79079423601 GAS RANGE
Kenmore 79079423603 GAS RANGE
Kenmore 79079424600 GAS RANGE
Kenmore 79079424601 GAS RANGE
Kenmore 79079424602 GAS RANGE
Kenmore 79079429600 GAS RANGE
Kenmore 79079429601 GAS RANGE
Kenmore 79079429602 GAS RANGE
Kenmore 79079432800 GAS RANGE
Kenmore 79079432801 GAS RANGE
Kenmore 79079433800 GAS RANGE
Kenmore 79079433801 GAS RANGE
Kenmore 79079433802 GAS RANGE
Kenmore 79079439800 GAS RANGE
Kenmore 79079439801 GAS RANGE
Kenmore 79079442600 GAS RANGE
Kenmore 79079442601 SEARS/RANGE
Kenmore 79079443600 GAS RANGE
Kenmore 79079443601 GAS RANGE
Kenmore 79079443602 GAS RANGE
Kenmore 79079449600 GAS RANGE
Kenmore 79079462600 DUAL FUEL RANGE
Kenmore 79079462601 DUAL FUEL RANGE
Kenmore 79079462602 DUAL FUEL RANGE
Kenmore 79079463600 DUAL FUEL RANGE
Kenmore 79079463601 DUAL FUEL RANGE
Kenmore 79079463602 DUAL FUEL RANGE
Kenmore 79079463603 DUAL FUEL RANGE
Kenmore 79079469600 DUAL FUEL RANGE
Kenmore 79079469601 DUAL FUEL RANGE
Kenmore 79079469602 DUAL FUEL RANGE
Kenmore 79079523600 DUAL FUEL RANGE
Kenmore 79079523601 DUAL FUEL RANGE
Kenmore 79079523602 DUAL FUEL RANGE
Kenmore 79079523603 DUAL FUEL RANGE
Kenmore 79079523604 DUAL FUEL RANGE
Kenmore 79079613800 GAS RANGE
Kenmore 79079613801 GAS RANGE
Kenmore 79079623700 SEARS PRO/GAS RANGE
Kenmore 79079627700 SEARS PRO/GAS RANGE
Kenmore 79079653700 GAS RANGE
Kenmore 79079653701 GAS RANGE
Kenmore 79079653703 GAS RANGE
Kenmore 79079653704 GAS RANGE
Kenmore 79079653705 GAS RANGE
Kenmore 79079653706 GAS RANGE
Kenmore 79079653707 GAS RANGE
Kenmore 79079653708 GAS RANGE
Kenmore 79079653709 GAS RANGE
Kenmore 7907965370A GAS RANGE
Kenmore 79079912300 GAS RANGE
Kenmore 79079912301 GAS RANGE
Kenmore 79079912302 GAS RANGE
Kenmore 79079913300 GAS RANGE
Kenmore 79079913301 GAS RANGE
Kenmore 79079913302 GAS RANGE
Kenmore 79079914300 GAS RANGE
Kenmore 79079914301 GAS RANGE
Kenmore 79079914302 GAS RANGE
Kenmore 79079919300 GAS RANGE
Kenmore 79079919301 GAS RANGE
Kenmore 79079919302 GAS RANGE
Kenmore 79079992100 GAS RANGE
Kenmore 79090033500 ELECTRIC RANGE
Kenmore 79090033502 ELECTRIC RANGE
Kenmore 79090033503 ELECTRIC RANGE
Kenmore 79090033504 ELECTRIC RANGE
Kenmore 79090043600 ELECTRIC RANGE
Kenmore 79090043601 ELECTRIC RANGE
Kenmore 79090102200 ELECTRIC RANGE
  #2 (permalink)
Old 12-07-2016, 02:45 PM
ThatGuy's Avatar
APP Volunteer
ThatGuy is on a distinguished road
Just like the broil side you should have around 120 volts going to the ignitor. If the ignitor and gas valve are OK, you need to find out were the break in the voltage is.
I suspect a bad connection or bad relay or burnt trace on the computer control board.
If it is the board you could replace the board or have it repaired.
Frigidaire 316418751 Clock/timer - AppliancePartsPros.com
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bake igniter not coming on. ricky1842 Oven Repair (including Ranges and Cooktops) 0 04-08-2013 08:14 PM
Igniter has continuity but will not glow amvivaldi Dryer Repair 10 05-25-2012 11:04 AM
no power bake/broil igniter lwalk50 Oven Repair (including Ranges and Cooktops) 0 12-29-2011 12:17 PM
Water Inlet Valve Shows Continuity but overflows Schoeman Dishwasher Repair 1 03-24-2011 01:23 PM
oven bake igniter nybdt1120 Oven Repair (including Ranges and Cooktops) 0 11-20-2009 03:01 PM
