Discuss
gas oven & display panel turns off when heating oven, recovers when cool
 in
I've done my research and read previous posts, but none are within 5 years. I want to verify and hopefully
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » gas oven & display panel turns off when heating oven, recovers when cool
  #1 (permalink)
Old 12-04-2016, 12:34 PM
Junior Member
Byrdson is on a distinguished road
Default gas oven & display panel turns off when heating oven, recovers when cool
Model Number: ARGS7650   Brand: Amana   Age: More than 10 years
I've done my research and read previous posts, but none are within 5 years. I want to verify and hopefully repair this issue and, of course, benefit others.
Model: ARGS7650SS (natural gas oven)
Mfg: P1130765NSS
Serial: 0011248891
Pic: 1102040303
My Amana gas oven display operates normally for all range top cooking, but the oven doesn't stay on and the entire front panel display goes dark (and silent) when the oven is heated up (typically higher temperatures). After it cools down, the display returns and all oven functions are back, but it will happen over and over if I try to heat up the oven. The clock seems to fall behind those minutes it is blank, so the clock needs to be adjusted to reflect the current time.
From my reading and research here, I believe there are two (2) parts that need to be replaced:
The Fan limit switch and the Control limit switch.
Yes, no, maybe? Those parts seems to be in rare supply, at best. I have basic tools, but no multimeter and zero electrical experience. I don't think I've heard a fan of any kind come on with that oven, if there is one. I could be wrong, but maybe the fan limit switch is bad, causing the fan to not come on, which shuts down the oven and display because the oven is too hot? Just my layman thoughts.
Thank you very kindly for your replies and comments.
Byrdson
Related Models
Amana ARGS7650CC RANGE- S/C S/I GAS
Amana ARGS7650E RANGE- S/C S/I GAS
Amana ARGS7650LL RANGE- S/C S/I GAS
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Amana ARHC8700WW RANGE- S/C F/S ELE
Amana ARHSC8750E RANGE- S/C S/I DDRAFT ELE
Amana ARHSC8750WW RANGE- S/C S/I DDRAFT ELE
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L RANGE- S/C S/I DDRAFT GAS
Amana ARO3100W RANGE- S/C S/I DDRAFT GAS
Amana ARO3400L RANGE- S/C S/I DDRAFT GAS
Amana ARO3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR-201 RANGE- S/C S/I DDRAFT ELE
Amana ARR-201 RANGE- S/C S/I DDRAFT GAS
Amana ARR-401 RANGE- S/C S/I DDRAFT ELE
Amana ARR-401 RANGE- S/C S/I DDRAFT GAS
Amana ARR-402 RANGE- S/C S/I DDRAFT ELE
Amana ARR-402 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT ELE
Amana ARR-412 RANGE- S/C S/I DDRAFT ELE
Amana ARR-415 RANGE- S/C S/I DDRAFT ELE
Amana ARR101W RANGE- S/C S/I DDRAFT ELE
Amana ARR301 RANGE- S/C S/I DDRAFT ELE
Amana ARR301W RANGE- S/C S/I DDRAFT ELE
Amana ARR303 RANGE- S/C S/I DDRAFT ELE
Amana ARR303W RANGE- S/C S/I DDRAFT ELE
Amana ARR305 RANGE- S/C S/I DDRAFT ELE
Amana ARR3100L RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 02-07-2017, 01:03 PM
Junior Member
Default Follow-up from the experts?
I see over 100 views of this post and it has been 3 month since I posted it.
Anyone have some wisdom for this, please?
Thank you kindly,
Byrdson
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire oven display light turns on and off repeatedly Snizzy Oven Repair (including Ranges and Cooktops) 2 10-20-2014 10:15 AM
Oven display turns off when heating rikrobb Oven Repair (including Ranges and Cooktops) 0 02-05-2013 12:32 PM
Amana Oven Turns On Keeps Heating Gerrypower Oven Repair (including Ranges and Cooktops) 0 12-20-2011 09:54 AM
Oven control panel fritzing out (turns oven back on!) mcuth Oven Repair (including Ranges and Cooktops) 0 05-20-2011 10:05 AM
Oven & broiler turns off while pre-heating jnelson Oven Repair (including Ranges and Cooktops) 0 12-26-2008 06:40 PM
