Discuss
Thermal fuse OK Bottom will not heat/broil
 in
Double Oven, Have replaced thermal fuse twice both check good continuity Service Tech says 240V coming in to front panel.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermal fuse OK Bottom will not heat/broil
  #1 (permalink)
Old 11-30-2016, 06:54 AM
Junior Member
Peedy is on a distinguished road
Default Thermal fuse OK Bottom will not heat/broil
Model Number: 79049443410   Brand: -brand-   Age: 1 - 5 years
Service Tech says 240V coming in to front panel. In spite has ordered another
one but did not pull oven to check. This is only part that can cause this
Can not there be another problem such as control board or relay board that will not let bottom work. All panel lights work and can hear switching but no heat
Related Models
Kenmore 79060001400 GAS RANGE
Kenmore 79060002400 GAS RANGE
Kenmore 79060002401 GAS RANGE
Kenmore 79060002402 GAS RANGE
Kenmore 79060002403 GAS RANGE
Kenmore 79060012600 GAS RANGE
Kenmore 79060012601 GAS RANGE
Kenmore 79060012602 GAS RANGE
Kenmore 79060012604 GAS RANGE
Kenmore 79060031100 ELECTRIC RANGE
Kenmore 79060042400 ELECTRIC RANGE
Kenmore 79060042401 ELECTRIC RANGE
Kenmore 79060042402 ELECTRIC RANGE
Kenmore 79060042403 ELECTRIC RANGE
Kenmore 79060042404 ELECTRIC RANGE
Kenmore 79060042405 ELECTRIC RANGE
Kenmore 79060042406 ELECTRIC RANGE
Kenmore 79060071790 ELECTRIC RANGE
Kenmore 79060071791 ELECTRIC RANGE
Kenmore 79060071792 ELECTRIC RANGE
Kenmore 79060071793 ELECTRIC RANGE
Kenmore 79060071794 ELECTRIC RANGE
Kenmore 79060201200 ELECTRIC RANGE
Kenmore 79060201201 ELECTRIC RANGE
Kenmore 79060301300 ELECTRIC RANGE
Kenmore 79060301301 ELECTRIC RANGE
Kenmore 79060301302 ELECTRIC RANGE
Kenmore 79060702900 ELECTRIC RANGE
Kenmore 79060702901 ELECTRIC RANGE
Kenmore 79060702902 ELECTRIC RANGE
Kenmore 79060712900 GAS RANGE
Kenmore 79060712901 GAS RANGE
Kenmore 79060712902 GAS RANGE
Kenmore 79060720900 GAS RANGE
Kenmore 79060720901 GAS RANGE
Kenmore 79060720902 GAS RANGE
Kenmore 79060721900 GAS RANGE
Kenmore 79060721901 GAS RANGE
Kenmore 79060721902 GAS RANGE
Kenmore 79061031100 GAS RANGE
Kenmore 79061071790 GAS RANGE
Kenmore 79061081890 FREESTANDING GAS RANGE
Kenmore 79061081891 30" GAS RANGE
Kenmore 79061081892 30" GAS RANGE
Kenmore 79061081896 RANGE
Kenmore 79061130100 ELECTRIC RANGE
Kenmore 79061130101 ELECTRIC RANGE
Kenmore 79061130102 ELECTRIC RANGE
Kenmore 79061130103 ELECTRIC RANGE
Kenmore 79061131100 ELECTRIC RANGE
Kenmore 79061131101 ELECTRIC RANGE
Kenmore 79061131102 ELECTRIC RANGE
Kenmore 79061131103 ELECTRIC RANGE
Kenmore 79061201200 GAS RANGE
Kenmore 79061301300 SEARS/GAS RANGE
Kenmore 79061301301 GAS RANGE
Kenmore 79061750100 ELECTRIC RANGE
Kenmore 79061750102 ELECTRIC RANGE
Kenmore 79061750103 ELECTRIC RANGE
Kenmore 79061750104 ELECTRIC RANGE
Kenmore 79061750105 ELECTRIC RANGE
Kenmore 79061750106 ELECTRIC RANGE
Kenmore 79061751100 ELECTRIC RANGE
Kenmore 79061751102 ELECTRIC RANGE
Kenmore 79061751103 ELECTRIC RANGE
Kenmore 79061751104 ELECTRIC RANGE
Kenmore 79061751105 ELECTRIC RANGE
Kenmore 79061751106 ELECTRIC RANGE
Kenmore 79061752100 ELECTRIC RANGE
Kenmore 79061752102 ELECTRIC RANGE
Kenmore 79061752103 ELECTRIC RANGE
Kenmore 79061752104 ELECTRIC RANGE
Kenmore 79061752105 ELECTRIC RANGE
Kenmore 79061752106 ELECTRIC RANGE
Kenmore 79061754100 ELECTRIC RANGE
Kenmore 79061754102 ELECTRIC RANGE
Kenmore 79061754103 ELECTRIC RANGE
Kenmore 79061754104 ELECTRIC RANGE
Kenmore 79061754105 ELECTRIC RANGE
Kenmore 79061754106 ELECTRIC RANGE
Kenmore 79061759300 ELECTRIC RANGE
Kenmore 79061759301 ELECTRIC RANGE
Kenmore 79061759302 ELECTRIC RANGE
Kenmore 79062090100 ELECTRIC RANGE
Kenmore 79062090101 ELECTRIC RANGE
Kenmore 79062090102 SEARS/ELECTRIC RANGE
Kenmore 79062091100 ELECTRIC RANGE
Kenmore 79062091101 ELECTRIC RANGE
Kenmore 79062091102 SEARS/ELECTRIC RANGE
Kenmore 79064090300 ELECTRIC RANGE
Kenmore 79064090301 ELECTRIC RANGE
Kenmore 79064090302 ELECTRIC RANGE
Kenmore 79064090303 ELECTRIC RANGE
Kenmore 79064090304 ELECTRIC RANGE
Kenmore 79064090305 ELECTRIC RANGE
Kenmore 79064090306 ELECTRIC RANGE
Kenmore 79064090307 ELECTRIC RANGE
Kenmore 79064090308 ELECTRIC RANGE
Kenmore 79064090309 ELECTRIC RANGE
Kenmore 7906409030B ELECTRIC RANGE
Kenmore 79064091300 ELECTRIC RANGE
Kenmore 79064091301 ELECTRIC RANGE
Kenmore 79064091302 ELECTRIC RANGE
Kenmore 79064091303 ELECTRIC RANGE
Kenmore 79064091304 ELECTRIC RANGE
Kenmore 79064091305 ELECTRIC RANGE
Kenmore 79064091306 ELECTRIC RANGE
Kenmore 79064091307 ELECTRIC RANGE
Kenmore 79064091308 ELECTRIC RANGE
Kenmore 79064091309 ELECTRIC RANGE
Kenmore 7906409130A ELECTRIC RANGE
Kenmore 7906409130B ELECTRIC RANGE
Kenmore 79070102400 GAS RANGE
Kenmore 79070102401 GAS RANGE
Kenmore 79070104400 GAS RANGE
Kenmore 79070104401 GAS RANGE
Kenmore 79070112700 GAS RANGE
Kenmore 79070112701 GAS RANGE
Kenmore 79070112702 GAS RANGE
Kenmore 79070112703 GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No heat - thermal fuse blown tsaign Dryer Repair 0 03-30-2013 09:43 AM
Oven won't heat after replacing thermal fuse bill cote Oven Repair (including Ranges and Cooktops) 1 11-29-2012 01:28 PM
Bypass thermal fuse/thermsotat (no heat) leesrt Dryer Repair 2 12-27-2010 05:03 PM
had no heat,thermal fuse was bad,wont run at all oliverson Dryer Repair 0 11-02-2009 05:29 PM
Doesn't heat every use and already changed thermal fuse pmkinseed Dryer Repair 1 06-25-2009 03:50 PM
