Discuss
Dacor dual fuel oven
 in
When using the oven,the temperature is off by about 100 degrees when you bake using the bake only option.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dacor dual fuel oven
  #1 (permalink)
Old 02-20-2008, 08:15 PM
hlp1236 hlp1236 is offline
Junior Member
hlp1236 is on a distinguished road
Default Dacor dual fuel oven
Model Number: RSD305   Brand: Dacor   Age: 5 - 10 years
When using the oven,the temperature is off by about 100 degrees when you bake using the bake only option. However when using the convection bake option the temp is almost correct maybe 10-20 degrees off. I think there is a problem with the bottom element since things don't crisp up well. Is the element bad or could it be something else? Please help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-21-2008, 02:11 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the oven temperature sensor resistance.
In suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong - replace the oven temperature sensor.
If there is nothing wrong, then replace the ERC (electronic range control).
- The part number for the oven temperature sensor is AP3394241
- The part number for the ERC is AP3390975
The following article on our forum will explain in detail how to run a continuity test or measure a resistance using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag dual oven, lower oven won't work curt6 Oven Repair (including Ranges and Cooktops) 4 11-04-2008 01:26 PM
Dacor Oven won't heat devorahbee Oven Repair (including Ranges and Cooktops) 1 05-24-2008 10:56 PM
Dacor oven lights Elizabeth Siefker Oven Repair (including Ranges and Cooktops) 1 12-23-2007 09:45 AM
Dacor lower oven not heating innovatech Oven Repair (including Ranges and Cooktops) 0 10-25-2007 10:44 AM
bosch dual-fuel range - won't preheat sgarst Oven Repair (including Ranges and Cooktops) 0 10-18-2007 07:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
