My thermador scd302t lower wall oven stopped heating up all the way. It seems the problem did start after a self-clean cycle (which failed in the middle). Now when I turn it on it only goes to 100 degrees. I have left it on for hours and it only goes to about 150 degrees. Same on bake, broil or convection, although the fan and light come on OK. I replaced the thermostat, the baking element and also sent the relay board away for repair (which I swore was the problem). It is still doing the same thing (although the upper oven works perfectly). I tried to reset the hi-temp cut out, but that little red button wouldn't push in at all. Could this part be bad? Could it be something else? Or is it possible that the relay board wasn't repaired properly. I was betting on that being the problem! Thanks:
