I found that the glass baffle was loose in oven door, and when I opened it up I found that the retaining tabs were too wide for the glass size and that any replacement glass was the same size. I therefore fashioned my own retaining tab extensions out of sheet metal to hold the glass secure, and it seems to have worked fine. Is this okay with the oven temperatures?
