Discuss
Bottom oven element not working
 in
The bottom element in the stove doesn't work. I've measured the element with an ohmmeter and it's reading 27 ohms,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bottom oven element not working
  #1 (permalink)
Old 11-02-2009, 06:07 AM
Junior Member
lavrjn is on a distinguished road
Default Bottom oven element not working
Brand: Kelvinator   Age: More than 10 years
The bottom element in the stove doesn't work. I've measured the element with an ohmmeter and it's reading 27 ohms, I'm not sure what a serviceable element is supposed to read. I've also measured the voltage at the element wires and it was reading 165 V AC. Can anyone tell me what the element resistance should be and what voltage should be at the connection. This is an old stove and as soon as you turn it on the top element is coming on unlike my other stove where the top element only comes on in broil. I presume the top element is coming on only to speed up the heating of the stove and would immediately shut off when the oven reached it's selected temperature.
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bottom heating element in oven billham Oven Repair (including Ranges and Cooktops) 2 09-17-2010 02:45 PM
Oven bottom element will not shut off Wendy Myatt Oven Repair (including Ranges and Cooktops) 1 06-01-2009 07:29 AM
bottom element not working nlorenz Oven Repair (including Ranges and Cooktops) 2 04-10-2009 08:13 PM
Bottom Element Not Working scratchinmyhead Oven Repair (including Ranges and Cooktops) 0 07-28-2008 05:14 PM
Bottom Element not working Kevin G Oven Repair (including Ranges and Cooktops) 0 11-08-2007 06:20 PM
