I used my self clean option on my oven, set it and went to bed. When I got up in the morning it seemed fine, I wiped it out and all seemed good. When I went to use it the later that day it would not work, the element was burnt out and the blade had cracked in half on the motor cooling fan.
I have replaced the bottom element I have replaced the motor cooling fan
I had and electrician check the wiring to ensure there were no problems. The oven sounds like it is working but it will not heat up.
Please help as I am not sure what to check next on it,
Kenmore MD 30inch self cleaning wall oven C970-415222 ser NF05028816
