jackbuettner@msn.com
#1 Posted : Thursday, October 6, 2016 1:03:43 PM(UTC)
When trying to use the self cleaning option, the display beeps continually and will not shut off unless power is disconnected. The error code is FC. Any advise on how to fix it.
ThatGuy
#2 Posted : Sunday, October 9, 2016 5:42:53 PM(UTC)
ThatGuy
Groups: Expert
United States
I personally don't know much about your error code, but I did find this.
Jenn Air Range/Stove/Oven Displaying Fault Code FC
JJW9630AAB
Communication error between boards
The manufacturer has assigned this error or fault code to indicate a possible problem with the clock assembly circuitry or relay board. Check the wiring harness between the boards to be sure there is good connection. If that checks out, it could be that either the relay board is not sending the proper signal.
