We were cooking pizzas at 500 degrees and after we were finished the control panel lights went out and the range died. There seemed to be alot of heat coming from the control panel general area.
There is nothing on the display so no error code. Should I start with a new display asm or try some other trouble shooting?
I replaced the main card about 4 years ago due to the relays getting over heated.
Is this the same situation
