Discuss
Burner wont ignite
 in
I inherited a Maytag gas range. Three of the four burners work fine. However, when I turn on right rear
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burner wont ignite
  #1 (permalink)
Old 02-20-2008, 03:42 PM
Junior Member
cocm is on a distinguished road
Default Burner wont ignite
Model Number: CHG 9800 BAE   Brand: Maytag   Age: 5 - 10 years
I inherited a Maytag gas range. Three of the four burners work fine. However, when I turn on right rear burner, right front ignitor sparks instead of rear and no gas is released to either front or rear burner.
Ads By Google
Related Models
Maytag CHG9800AAB Range - S/c S/i Gas
Maytag CHG9800AAE Range - S/c S/i Gas
Maytag CHG9800BAB Range - S/c S/i Gas
Maytag CHG9800BAE Range - S/c S/i Gas
Maytag CHG9800BAM Range - S/c S/i Gas
Maytag CHG9830BAB Range - S/c S/i Gas
Maytag CHG9830BAE Range - S/c S/i Gas
Admiral CHGA400BAB Range - S/c S/i Gas
Admiral CHGA400BAE Range - S/c S/i Gas
Whirlpool CHS12RC
Whirlpool CHS12RC1
Whirlpool CHS5A
Whirlpool CHS5A2
Whirlpool CHS5R
Whirlpool CHS5W
Whirlpool CHS5W2
Whirlpool CHS7RC
Whirlpool CHS7RS
Whirlpool CHTS4AECP
Whirlpool CHTS4WECP
Whirlpool CHTS6AECP
Whirlpool CHTS6WECP
Amana CI7.7 Freezer - Chest
Amana CI8.8 Freezer - Chest
Amana CI8.8-C Freezer - Chest
Amana CIC-3 Ref - Top Mount
Amana CIC-4H Ref - Top Mount
Amana CIC3 Misc / Accessory
Amana CIC4 Misc / Accessory
Amana CIC4H Misc / Accessory
Amana CIC4K Misc / Accessory
Maytag CIKHTM-1  Misc / Accessory
Maytag CIKHTM-1V  Misc / Accessory
Amana CIM105 Ref - Bottom Mounts
Amana CIM105L Ref - Bottom Mounts
Amana CIM125 Ref - Bottom Mounts
Amana CIM125L Ref - Bottom Mounts
Amana CIM98 Ref - Bottom Mounts
Amana CIM98L Ref - Bottom Mounts
Amana CIMR-19 Ref - SXS/I&W
Amana CIMR-22 Ref - SXS/I&W
Amana CIMR14 Misc / Accessory
Amana CIMR14L Misc / Accessory
Amana CIMS14 Misc / Accessory
Amana CIMS14L Misc / Accessory
Hardwick CJ1616A49R Range - F/s Std Gas
Hardwick CJ1616W49R Range - F/s Std Gas
Hardwick CJ1626A49R Range - F/s Std Gas
Hardwick CJ1626W49R Range - F/s Std Gas
Thermador CJ302UB
Thermador CJ302US
Thermador CJ302UW
Thermador CJ302ZS
Hardwick CJ7121809RC Walloven - Std Gas
Hardwick CJ7122809RC Walloven - Std Gas
Hardwick CJ7141809RC Walloven - Std Gas
Hardwick CJ7141819DE Walloven - Std Gas
Hardwick CJ7142809RC Walloven - Std Gas
Hardwick CJ9641A590R Range - F/s Std Gas
Hardwick CJ9641W590R Range - F/s Std Gas
Amana CJW1008.A Commercial Microwaves
Amana CJW1008.B Commercial Microwaves
Amana CJW1008.Z Commercial Microwaves
Amana CJW1040.A Commercial Microwaves
Amana CJW1040.B Commercial Microwaves
Amana CJW1040.Z Commercial Microwaves
Gaggenau CK062-604
Gaggenau CK064-604
Gaggenau CK066-604
Gaggenau CK067-604
Gaggenau CK069-604
Gaggenau CK074-604
Gaggenau CK074-614
Gaggenau CK074-624
Gaggenau CK163-604
Gaggenau CK169-604
Gaggenau CK260-604
Gaggenau CK270-604
Maytag CK277SS-1  Misc / Accessory
Maytag CK277SS-1V  Misc / Accessory
Gaggenau CK390-615
Gaggenau CK394-615
Gaggenau CK396-615
Gaggenau CK590-615
Gaggenau CK596-615
Hardwick CKD7121810AC Walloven - Cont Clean Gas
Hardwick CKD7122810AC Walloven - Std Gas
Hardwick CKD7221819A Walloven - Cont Clean Gas
Hardwick CKD7221819AC Walloven - Std Gas
Hardwick CKD7222810AC Walloven - Std Gas
Hardwick CKD7222819A Walloven - Std Gas
Hardwick CKD7224810AC Walloven - Std Gas
Hardwick CKD7224819A Walloven - Std Gas
Hardwick CKD7241819A Walloven - Cont Clean Gas
Hardwick CKD7242819A Walloven - Std Gas
Hardwick CKD7244819A Walloven - Std Gas
Hardwick CKD9512W439R Range - F/s Cont Clean Gas
Hardwick CKD9512Y439R Range - F/s Cont Clean Gas
Hardwick CKD9516W421R Range - F/s Cont Clean Gas
Hardwick CKD9517W429R Range - F/s Cont Clean Gas
Hardwick CKD9521A439R Range - F/s Cont Clean Gas
Hardwick CKD9521W439R Range - F/s Cont Clean Gas
Hardwick CKD9521W79R Range - F/s Std Gas
Hardwick CKG4612MA539RG Range - F/s Cont Clean Gas
Hardwick CKG4612MW539RG Range - F/s Cont Clean Gas
Hardwick CKG4642MA639RG Range - F/s Cont Clean Gas
Hardwick CKG4642MW639RG Range - F/s Cont Clean Gas
Hardwick CKG8421MA729RG Walloven - Std Dbl Oven Gas
Hardwick CKG8421MW729RG Walloven - Std Dbl Oven Gas
Hardwick CKG9622W439RGB Range - F/s Cont Clean Gas
Hardwick CKG9641W589RGC Range - F/s Cont Clean Gas
Hardwick CKJ9641A580RW Range - F/s Cont Clean Gas
Hardwick CKJ9641W580RW Range - F/s Cont Clean Gas
Hardwick CKM9641A580RW Range - F/s Cont Clean Gas
Hardwick CKM9641A589RGD Range - F/s Cont Clean Gas
Hardwick CKM9641W580RW Range - F/s Cont Clean Gas
Hardwick CKM9641W589RGC Range - F/s Cont Clean Gas
  #2 (permalink)
Old 02-20-2008, 04:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
All four burner igniters are on the same circuit and should spark wherever burner is turned "on".
Did you hear the whistling sound when the right rear burner was turned "on"?
Check the right rear burner igniter for cracked and/or broken ceramic insulation.
Remove the burner (turn it CCW) and check for broken and/or loose wires.
Post your findings.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-21-2008, 03:46 PM
Junior Member
Default
Problem solved; control module was defective.
  #4 (permalink)
Old 02-21-2008, 04:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
  #5 (permalink)
Old 02-23-2008, 03:38 PM
Junior Member
Default
Gene:
Thanks for responding. I appreciate the help.
COCM
  #6 (permalink)
Old 02-23-2008, 06:41 PM
Junior Member
rkeller is on a distinguished road
Default no heat
hello,
I have a whirlpool gas dryer Model # LGR8648PW.
i belive the problem is with the igniter but not sure.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burner want ignite mflorence Oven Repair (including Ranges and Cooktops) 2 02-26-2010 06:18 PM
Oven Burner after ingnited wont stay lit, ingniter continues to try to ignite mhardy2 Oven Repair (including Ranges and Cooktops) 0 11-06-2009 09:23 AM
one burner won't ignite woolyone Oven Repair (including Ranges and Cooktops) 0 10-17-2009 04:56 PM
Burner doesn't ignite kurtloth Dryer Repair 3 03-17-2009 04:37 AM
Burner will not ignite Joyce Todd Dryer Repair 0 07-20-2008 08:01 PM
