New condo, stove was there when I moved in. All worked fine for a few months. Then the oven wouldn't light but the broiler was ok. Then a day later the broiler wouldn't work either. When I attempt to turn either on, there is no smell of gas or any indication that ANYTHING is going on. I suspect it is an ignitor, but not sure if there are separate ones for oven and broiler.
