Oven went out completely - no lights, buttons unresponsive, etc. Discovered the thermal fuse went out so I replaced it and the oven worked again for 3 days before the new thermal fuse went out. The second time I noticed that the control panel with buttons was really hot.
I can order another thermal fuse, but why is the top of the oven with the controls getting so hot? Do I need to replace a fan as well? Maybe the heat is not being vented and is heating up the control panel and blowing the fuse? Thanks for any help before I order any more parts.
Charlie
