read a lot about this, but:
started to get an f3 error code..temp sensor. when i use timer sometimes a f1 code...control module. used oven tonight...no codes at all. can temp sensor effect control module to send f1 code using timer? or is temp sensor fine and control module bad? read about 2 serial numbers..starting 16 or 17 for 2 different modules used...mine is 121264475.
