No power showing on the control board at all. Power to plug check, power to terminal block check, power to board terminal wire ends check. Top burners work just nothing on the board. Have looked for transformer problem under the stove checked it and it is good. Second board sold as working, its used, installed still no indication that the board has power yet. Anyone have this problem before? Mama's not happy so everyone is not happy. HELP
