within the last week, we had an issue with the oven losing power during the self cleaning cycle,. I found that the thermal fuse had gone out and replaced it. Thank you this site for the instructions. We used the oven several times over the last week. Last night we were baking and the oven powered off again, this time it started power cycling off and on several times until I powered it off at the breaker. This morning it powered back on without issue now that the oven has cooled down. Is there another sensor of fuse that needs to be replaced on this oven? If so where is it located?
Thank you for your help Sean
