LP to Nat Conversion Question
This range was first used with LP. It is now being used in a home that uses Natural Gas. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » LP to Nat Conversion Question
  #1 (permalink)
Old 11-01-2009, 08:33 AM
Junior Member
garciam9 is on a distinguished road
Default LP to Nat Conversion Question
Model Number: JGBP26WEH2WW   Brand: GE   Age: 1 - 5 years
This range was first used with LP. It is now being used in a home that uses Natural Gas. I changed the vent valve/flow restrictor in the pressure regulator, and Iíve changed the spuds for the top burners. That all works fine.
But as for the oven, I can't seem to get the main burner to fire up. I get gas out of it; the igniter glows nice and strong; but no ignition. As for the broiler, it does ignite, but just seems to be so weak.
What else is wrong? Is it not flowing enough gas? Is there an orifice that needs to change? What do I need to do?
Related Models
General Electric JGBP26WEH2WW Gas range
General Electric JGBP26WEH3WW Gas range
General Electric JGBP26WEH4WW Gas range
General Electric JGBP26WEH5WW Gas range
General Electric JGBP26WEH6WW Gas range
General Electric JGBP26WEV1WW Gas range
General Electric JGBP26WEV2WW Gas range
General Electric JGBP26WEV3WW Gas range
General Electric JGBP26WEV4WW Gas range
General Electric JGBP26WEW1WW Gas range
General Electric JGBP27BEA1AD Gas range
General Electric JGBP27BEA1WH Gas range
General Electric JGBP27BEA2AD Gas range
General Electric JGBP27BEA2WH Gas range
General Electric JGBP27BEA3AD Gas range
General Electric JGBP27BEA3WH Gas range
General Electric JGBP27BEA4AD Gas range
General Electric JGBP27BEA4WH Gas range
General Electric JGBP27BEA5AD Gas range
General Electric JGBP27BEA5WH Gas range
General Electric JGBP27BEA6AD Gas range
General Electric JGBP27BEA6WH Gas range
General Electric JGBP27BEW1AD Gas range
General Electric JGBP27BEW1WH Gas range
General Electric JGBP27DEM1WW GAS RANGE
General Electric JGBP27DEM2WW GAS RANGE
General Electric JGBP27DEM3WW GAS RANGE
General Electric JGBP27DEM4WW GAS RANGE
General Electric JGBP27DEM5WW GAS RANGE
General Electric JGBP27DEM6WW GAS RANGE
General Electric JGBP27GEH1 Gas range
General Electric JGBP27GEH2 Gas range
General Electric JGBP27GEH3 Gas range
General Electric JGBP27GEJ1 Electric range
General Electric JGBP27GEJ2 Gas range
General Electric JGBP27GEJ3 Gas range
General Electric JGBP27GEJ4 Gas range
General Electric JGBP27GEJ5 Gas range
General Electric JGBP27GEN1 GAS RANGE
General Electric JGBP27GEV1AD Gas range
General Electric JGBP27GEV1WH Gas range
General Electric JGBP27GEV2AD Gas range
General Electric JGBP27GEV2WH Gas range
General Electric JGBP27GEV3AD Gas range
General Electric JGBP27GEV3WH Gas range
General Electric JGBP27SEV1AD Gas range
General Electric JGBP27SEV1WH Gas range
General Electric JGBP27SEV2AD Gas range
General Electric JGBP27SEV2WH Gas range
General Electric JGBP27WEL1WW Gas range
General Electric JGBP27WEL2WW GAS RANGE
General Electric JGBP28BEA1AD Gas range
General Electric JGBP28BEA1CT Gas range
General Electric JGBP28BEA1WH Gas range
General Electric JGBP28BEA2AD Gas range
General Electric JGBP28BEA2CT Gas range
General Electric JGBP28BEA2WH Gas range
General Electric JGBP28BEA3AD Gas range
General Electric JGBP28BEA3WH Gas range
General Electric JGBP28BEA4AD Gas range
General Electric JGBP28BEA4WH Gas range
General Electric JGBP28BEA5AD Gas range
General Electric JGBP28BEA5WH Gas range
General Electric JGBP28BEA6WH Gas range
General Electric JGBP28BEA7WH Gas range
General Electric JGBP28BEH1CT Gas range
General Electric JGBP28BEH1WH Gas range
General Electric JGBP28BEH2CT Gas range
General Electric JGBP28BEH2WH Gas range
General Electric JGBP28BEH3CT Gas range
General Electric JGBP28BEH3WH Gas range
General Electric JGBP28BEJ1CT Gas range
General Electric JGBP28BEJ1WH Gas range
General Electric JGBP28BEJ2CT Gas range
General Electric JGBP28BEJ2WH Gas range
General Electric JGBP28BEJ3CT Gas range
General Electric JGBP28BEJ3WH Gas range
General Electric JGBP28BEK1CT Gas range
General Electric JGBP28BEK1WH Gas range
General Electric JGBP28BEK2CT Gas range
General Electric JGBP28BEK2WH Gas range
General Electric JGBP28BEK3CT Gas range
General Electric JGBP28BEK3WH Gas range
General Electric JGBP28BEL1CT Gas range
General Electric JGBP28BEL1WH Gas range
General Electric JGBP28BEL2CT Gas range
General Electric JGBP28BEL2WH Gas range
General Electric JGBP28BEL3CT GAS RANGE
General Electric JGBP28BEL3WH GAS RANGE
General Electric JGBP28BEL4CT GAS RANGE
General Electric JGBP28BEL4WH GAS RANGE
General Electric JGBP28BEW1AD Gas range
General Electric JGBP28BEW1WH GAS RANGE
General Electric JGBP28CEM1WW GAS RANGE
General Electric JGBP28CEM2WW GAS RANGE
General Electric JGBP28CEM3WW GAS RANGE
General Electric JGBP28CEM4WW GAS RANGE
General Electric JGBP28CEM5WW GAS RANGE
General Electric JGBP28CEM6WW GAS RANGE
General Electric JGBP28DED1CT Gas range
General Electric JGBP28DED1WH Gas range
General Electric JGBP28DED2CT Gas range
General Electric JGBP28DED2WH Gas range
General Electric JGBP28DEH1CT Gas range
General Electric JGBP28DEH1WH Gas range
General Electric JGBP28DEH2CT Gas range
General Electric JGBP28DEH2WH Gas range
General Electric JGBP28DEH3CT Gas range
General Electric JGBP28DEH3WH Gas range
General Electric JGBP28DEJ1CT Gas range
General Electric JGBP28DEJ1WH Gas range
General Electric JGBP28DEJ2CT Gas range
General Electric JGBP28DEJ2WH Gas range
General Electric JGBP28DEJ3CT Gas range
General Electric JGBP28DEJ3WH Gas range
General Electric JGBP28DEL1CT Gas range
General Electric JGBP28DEL1WH Gas range
General Electric JGBP28DEL2CT Gas range
General Electric JGBP28DEL2WH Gas range
General Electric JGBP28DEL3CT GAS RANGE
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Nat. To Lp Conversion jrcouldry Oven Repair (including Ranges and Cooktops) 1 02-21-2010 03:39 PM
nat to lp conversion bikerbob484 Oven Repair (including Ranges and Cooktops) 0 01-18-2010 08:46 AM
LP conversion kit madammim Dryer Repair 1 09-11-2009 08:16 PM
ng to lp conversion rogerl Oven Repair (including Ranges and Cooktops) 1 04-09-2009 03:39 PM
Conversion to LP chuchin51 Oven Repair (including Ranges and Cooktops) 4 03-01-2009 08:54 AM
