Hi I have a Jenn Air S176 w that stops preheating the oven for no reason. No codes come up on control panel. The readout shows that it is heating but never reaches the set temperature. When this happens you cannot get the broiler to function either. I have replaced the oven temperature sensor but that did not solve the problem. Could it be the oven high limit switch?
