Some years ago an appliance repair tech swapped my broil igniter for my broken bake igniter. I now felt it time to replace both due to the bake igniter again starting to fail. I easily replaced the bake igniter, connecting it to the same wires i disconnected it from. The broil igniter is not as easy, due to it being out for some time and I don't know where the second white wire from the igniter goes. The bake igniter connected to a red wire and to the gas control valve. It looks like one wire from the broil igniter should connect to a violet wire from the gas control valve, the second igniter wire is where i'm unsure, there are no other unused wires. Where does the second broil igniter connect???
